390 freeze plugs
390 freeze plugs
hello all,
I have some questions about freeze plugs.
my truck is a 2wd/ 69/ f100/ FE390
Do i have to pull the motor out to replace the plugs?
only one rusted thru (driver side, middle)... but i decided there are more that are close... so im gonna replace them all
Ive also read that brass plugs are the way to go
also, are there plugs inside the bellhousing that touch antifreeze?
Or just the six on the block?
thanks in advance, -Luke
on
Just be careful and jack up the motor some remove frame mount if needed. I use a socket an a old short extension for a driver. It will mess up the end from hammering on. I only use this extension for driving in freeze plugs for the pass 35 yrs. Their's is 6 freeze the size is 1.3/4" Yeah brass is the only way to go. I use a small wire wheel with a drill to clean the inside walls for a good seal and the plugs go in easier. I put rtv on them when installing them for a better water seal.. Yeah was you get started just keep going until you get them all replaced. No freeze plugs behine the fly wheel...
orich
orich
73 f100 with 390
hello, I am attemping to replace my freeze plugs. It appers as if the passager side is the problem. I know I sould replace all but untill the weather is nicer I just need to adress the problem at hand, the leak. Not sure where they are located and if I must pull the engine. I do not have the tools for that. Nor do I have the money to take it to a shop. Diy has always been my motto. Any advice?
Thanks,
Beth
Thanks,
Beth
on
There's a few ways too go to fix it the OEM type steel are a little easier then brass.
But, I used the Dorman temp to fix them. I installed 29 yrs ago in my x-in laws 62 Mercury 352 fe and it's still in and not leaked yet. I did use JB weld for a sealer though as this was all at hand at the time. This was the one I used.. DORMAN QUICK SEAL EXPANSION PLUG, COPPER -- 1.63 in. size, 1.78 in. maximum expansion; A high quality, direct fit OE.. Now, I have used the rubber one's yrs ago with good and bad luck. The bad was in a 1967 390 block they have popped out on me two times on the road at high rpm when shifted to 3rd gear going up a steep hill so I'd say don't use the rubber type.. orich
core plugs
Lukey, When you have the plug out of the engine take a garden hose and flush out the inside of the block until clear water starts flowing back out. You will not believe the sludge that is inside the block. Just like Orich said use a wire wheel . If you have to use a rubber plug be very sure that the hole is clean and dry ,do not use any sealer. Kenny
Woah! all of a sudden my old, dead thread explodes
Thanks for the advise!
I ended up just putting a rubber plug in like 6 months ago, just to hold fluid in cause i really never use the truck thanks to our amazing gas prices...
It holds just fine, but id feel better replacing them all with brass, since others are probably close...
I'm thinking that I'm gonna sell the truck soon, but id like to get the freeze plugs taken care of first, so that they aren't a problem for someone else down the road.
I don't have a cherry picker, but my uncle has one that I've borrowed, but id rather not take the whole thing out if I don't have to...
Will this give me enough clearance to get at them with the engine still in the bay?
Im off school now till January so maybe if i get bored someday ill try get them done... we will see
