How to: 3G install for 83-92 IDIs
#31
#32
#33
Thanks for the reply. I didn't expect much difference, but I wasn't sure if someone had a good reason NOT to. I'll run it on mine. I figure might as well use it since it's there. I'll only need an extra 6-8" of wire given the harness I pulled.
#34
I run them to the battery to account for voltage drop through the charge cable. Anything less is just being lazy.
#35
To throw out some PNs to help others....
If you have a dual v-belt setup (as opposed to serpentine belt), this PN is a direct drop-in alternator (130A, large case) that will come with the right pulley and clocked perfectly: 7756-3N-2G. Supposedly, this was one of the options offered on a 92 E350 IDI. You will need a M8x1.25mm bolt for the top (25m worked well for me), and likely a corresponding fender washer to ensure the bolt head won't pull through the alternator arm. I found a brand new one on eBay for $100.
As for the wiring, I found countless folks on eBay offering very reasonably-priced harnesses and kits. Yes, you can wire it yourself, but the harness I found was about $20 shipped and had all the terminations I needed. I only had to splice the red/green wire off the regulator harness and was good to go. Other than that, you just need a length of 4 ga wire, a fuse holder that can hold a fuse rated at 175A, and the appropriate terminations.
Mike
Mike
#36
#37
#38
I glanced through and didn't see it, sorry if I missed it but has anyone had issues with belt length?
I put one on my 91 and the belt is too long. Its a new belt but its flapping against the lower mounting bolt and wearing a ridge.
Only thing I can tell is the spacing from the lower mount bolt to the center of the pulley is shorter than the old alternator.
#40
#41
Look at this on eBay http://www.ebay.com/itm/321881681242
Red wire goes to green wire. I think I found another kit that came with this AND the bit of 4ga wire and mega fuse holder you'll need, but I can't remember now. When i did the job, I also removed the entire harness from the truck so I could strip out everything I didn't need, then dressed it back up real nice before I put it back. Didn't take long, and I'm glad I did it. Gives the job a nice clean look.
Mike
#43
https://www.ford-trucks.com/forums/1...idi-guide.html
#44
That`s the problem when people put up a good thread with pictures linked
from their Photo Bucked acct. then delete the account. everything is gone.
Kind of makes the thread useless when doing a search. I see this over and over
here on this forum and others.
Charlie
#45
I re-wrote this guide with new pictures on a different part of the forum. Shameless plug herre:
Thank you for the link, great pictures and detailed how to.
Charlie
