EGR Delete
Old Apr 18, 2012 | 04:25 PM
Regulator1988's Avatar
Regulator1988
EGR Delete
So I'm trying to do this my self and some people told me that you have to take the cab off to do it... is this true?
Old Apr 18, 2012 | 04:53 PM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
I can't imagine why you'd need to pull the cab. Unless you really want reeeeaallly easy access to the up-pipe?
Sinister has a good set of instructions:
http://www.thoroughbreddiesel.com/pe...ctions_1-4.pdf
http://www.thoroughbreddiesel.com/pe...ctions_5-8.pdf
Old Apr 18, 2012 | 05:55 PM
2006powerstroke90's Avatar
2006powerstroke90
LOL I couldn't imagine why anyone would say that.
Old Apr 18, 2012 | 05:58 PM
Regulator1988
Ok what about which one is best
Old Apr 18, 2012 | 06:01 PM
2006powerstroke90
Which one is the best what?
Why are you even deleting the egr??
Old Apr 18, 2012 | 06:05 PM
Regulator1988
i was told that the egr was the problem with the 6.0s
Old Apr 18, 2012 | 06:06 PM
2006powerstroke90
Alright, I wouldn't fix it if it's not broken.
I would first figure out your temps then worry about it.
You have a good strong egr cooler in that truck.
Old Apr 18, 2012 | 06:12 PM
Regulator1988
and on a scale from 1-10 how hard is it and about how long do you think itll take
Old Apr 18, 2012 | 06:16 PM
Regulator1988
Ok what about oil cooler?
Old Apr 18, 2012 | 06:21 PM
2006powerstroke90
It all depends on how good you are working on trucks.
For anyone who has been there on a 6.0 before its probably a 4
The oil cooler is the same as the others I believe.
Get gauges to monitor temps first.
Old Apr 18, 2012 | 06:44 PM
Regulator1988
I'm getting the Sct insite
Old Apr 18, 2012 | 06:59 PM
BLADE35's Avatar
BLADE35
Yes get your temps just like Tyler is Telling you
You will be Pissed to go in to do the EGR Deleate and leave a BAD Oil cooler
your 03 has a round EGR Cooler there the Good Ones its already built like a Upgraded BPD EGR Cooler
I was in same boat as you as in owning an 03 and doing the egr deleate
I went ahead and did a VERY VERY thuro coolant system flush and did the egr deleate and changed the oil cooler and upgraded to an ELC CAT EC-1 Silicate Free Coolant at that time and synthetic oil and Alll new gaskets cleaned intake manafold and all sensors within it left the EGR Valve installed and plugged in too just removd the egr coooler
I spread it out over 4 days 1 day was spent coolant flushing 8hr and 1/2 tank fuel flushing DO NOT CUT CORNERS FLUSHING. My oil coooler has 15k since it was redone and since I took the time to flush and do it right the temp deltas are still the same as when it was new
So plan on a couple Days Minimum
If I try to Hurrey threw and set a land speed record thats when I miss stuff forget things install wrong order and end up causing myself GREIF
So set enough time aside to do it that you dont need the truck and have to rush threw it Make shure its done right and NOTHING Missed
So get all your Ducks in a row first and address everything that needs it as you go
Old Apr 18, 2012 | 10:32 PM
Regulator1988
If 03 was the best why did you delete it?
Old Apr 19, 2012 | 10:55 AM
BLADE35's Avatar
BLADE35
Anything can Fail the 03 dontfail very often at all but anythings possible kinda like winning the lottery I guess
I gained about 2 mpg to and intake stays clean and sensors within it
wanted to change the uppipe
All the EGR Cooler worries are GONE
Old Apr 19, 2012 | 10:58 AM
Regulator1988
You gained 2mpg?
