5speed conversion
Old Apr 17, 2012 | 05:45 PM
1983/84f350's Avatar
1983/84f350
5speed conversion
have a 83 f350 with a 6.9 i am putting a 351w in it. I am pretty sure the old 4speed from the 6.9 will not work. I have a 5speed for a 351w from 89 truck both are 4wd trans. will this go in easy or do i need to "modify" for it to work ??
Old Apr 17, 2012 | 06:11 PM
Franklin2's Avatar
Franklin2
Should be fairly easy. You will have to change your hydraulic clutch system around a little bit, I believe your diesel has a external slave cylinder while the 351w I think is internal type slave. Check this out, and get the correct lines and stuff, the clutch master should still work.
Old Apr 17, 2012 | 06:22 PM
1983/84f350
Thanks for the info i will look into it
Old Apr 17, 2012 | 07:00 PM
IDIDieselJohn's Avatar
IDIDieselJohn
The 351 will have an internal slave.
The big blocks, and diesel were the only ones to have an external slave in the hydraulic clutch years.
Whiteraisin
Oct 21, 2012 08:07 AM
Blue Rebel
20
Mar 14, 2010 10:52 PM
Steve
Jan 8, 2007 11:01 PM
CantedValve
Dec 2, 2002 11:46 PM
