Any Intakes Kits Worth It?
I dont know why I have a strong urge to buy a intake kit, I see they are around $200 and all I see really for the 3 valve is the K&N, AFE and Poweraid.. I like the look of the K&N the best because it comes with the most parts and cost the same as the AFE and Poweraid..
What am I gaining for around $200, I doubt I will gain any mpg, I doubt I will gain any noticeable power.. So all I am getting is some points in the "cool department"?? I put an intake system on my wifes car and now there is a nice grow from under the hood, does it happen with the 6.8l as well??
One of the way to evaluate the technical merit of a product is to go to US patent department website and conduct a search on either company name or product description or both . You will see it right there , if it is proven technically . It works for me , it might work for you too .
Good luck,
Good luck,
on
I personally like the Airaid and IMHO the intake mod is a much better add-on than an exhaust kit. I also had an Airaid on my 2002 7.3 and it was alot easier to get off-on for cleaning than alot of the others. Took about 20 minutes to change from the stock setup to the Airaid on my 2008. I've had it on for 90,000 miles with no complaints.
Pap
Pap
First thing I did was change the intake back to stock (traded someone) from the K&N FIPK kit that my Excursion had on it. To noisy for me. I felt no performance gains. Note that most of them say "up to" so many HP and MPG gain. If they really worked then why don't they say "at least" so many HP and MPG? The stock V10 intake is known to be able to flow a lot more air then it will ever need. Put your money somewhere else.
I think the urge is because they're a cheap mod and the advertised gains are tempting. I've put them on three of my last vehicles and they were all a waste. More noise and no power. I actually did dyno tests on my '05 F-150 5.4 before and after putting on a cold-air system and high-flow cat-back exhaust. My power graphs looked just like what the intake mfgs show online, but reversed. Not only did I loose power, I was running my engine very lean. Ironically, I picked my air intake because it "was engineered specifically to prevent a lean condition on the 5.4 engine". So much for truth in advertising.
And the MPG savings will never happen. Your engine will detect the increased air and add more fuel to keep the right fuel-to-air ratio. In the end you'll still use the same amount of fuel to get down the road.
I live about 30 miles North of you. If you want to waste $200, I'll drive down and let you fill my tank.
I do believe in exhaust systems and have one on my V10. If I could get a free flowing quiet exhaust system I would run that in a heartbeat, but you can't have both. My V10 came with a Bassini exhaust system on it. For a V10 it is a gorgeous sound. Not very noisy till you get on it.
I also love the sound of boosted engines. I used to drive with the passenger window down so that I could listen to the turbo talking to me. Completely different conversation on the intake side.
I really thought these intakes are worth something, due to 5 star selling them in his performance packages.. Everyone has so much faith in 5 start and his tuner, but everyone knocks the intake he sells? Oh well more money for something else.. How about a throttle body spacer?? Just kidding haha
(meaning no offense, just trying to understand these darn intake systems haha)
