2005 SD 4x4 Diesel Transmission leak out vent
Hi all, new member thanks for your time.
I have a 2005 F250 Diesel 4x4.
Trans is leaking out the vent...
The truck drives fine.
I have checked fluid levels ok. (not overfull)
I have changed the trans filter near the cooler. (it was dirty, but not blocked)
I have check all lines for kinks. (none)
I have removed the pan to look for bits of metal... (only found small amount of sludge/fine debris on the magnet.)
My heavy truck dealer's only option after my work would be to open up/rebuild.
Any additional ideas I might try would be appreciated!
Thanks
Steve
Thanks
Steve
kingnothingness
2004 - 2008 F150
05-15-2019 07:25 PM
