400 engine
Old Apr 30, 2003 | 07:35 PM
400miller's Avatar
400miller
400 engine
I was planing on putting in comp cams k kit edelbrock intake and carb and when i pulled the cam a part of the bearing came with it. their was a hand full of metal in my oilpan. i pulled the motor and replaced all of my bearings and got it bored. whats the displacement of a .30 over 400. anybody have problems with the c6 transmission. should i upgrade the oiling system. the engine only has 60000 miles on it
Old Apr 30, 2003 | 08:25 PM
grclark351's Avatar
grclark351
400 engine
408.2", according to http://users.abilene.com/~dkelly/hot...mpression.html
as for oiling mods the moroso restrictor kit can only help. you may want to enlarge the hole in the restrictor slightly for the lifters if you are running hydraulic. i would also go with a high volume pump
