Front leaf spring question
Old Apr 13, 2012 | 08:18 PM
95f2504x4's Avatar
95f2504x4
So today while I was out i seen a 1997 Ford F350 7.3 powerstroke so I pulled over and looked at it. I thought it had a little bit of a lift on it and then I started looking and there was no lift on it. When i looked at the tires they were the same size as mine but there was more of a spacing between the tire and fender on this truck. Now i have a 95 F250 with a 351w and the ifs dana 50 the truck i seen had a powerstroke and solid axle (dana 60?). Now with the truck having the powerstroke (or the solid axle) does that make it have to have a different front leaf spring so it can support the weight. And would I get any sort of lift by getting a set of springs for a 460 or powerstroke truck since it doesnt have to support as much weight?
Old Apr 13, 2012 | 10:50 PM
GNR22's Avatar
GNR22
The F350 (One Ton) and your F250 (3/4 Ton) have different weight capacities, and to meet those capacities yes, they do use different springs. You don't have the same trucks. The F350 uses a Dana 60 Straight Axle and your truck uses a Dana 50 Twin Traction Beam. I would highly doubt you would gain any height by using the springs out of a truck that has a big block because the springs are probably more worn out.
Old Apr 14, 2012 | 07:36 AM
95f2504x4's Avatar
95f2504x4
I didnt mean take a set off another used truck I meant more like find a set of new ones, and see if those gave any lift to it. Also would the F350 springs fit where my springs would go, or is there any sort of modification that needs to be done?
Old Apr 14, 2012 | 09:38 AM
Diesel_Brad's Avatar
Diesel_Brad
F350 springs will NOT work in your F250 truck unless you use the F350 dana 60 front axle too.
F250 springs have a spring rate of approx 3,400lbs
F350 springs have a spring rate of approx 2,200lbs
The reasoning behind this is that the F250 spring not only has to move up and down, it has to follow the arch of the axle when if flexes. The f350 spring just has to move up and down.
if you use f350 springs in your F250, the truck would sit about the same as what you have now and then it would sag BADLY from flexing the spring beyond the way it was designed.
If you want more lift from your springs, you can add and add-a-leaf and get the truck aligned about a week after the add-a-leaf is installed(to allow for settling)
Old Apr 14, 2012 | 01:06 PM
RJJP's Avatar
RJJP
Not so much the arc, but the fact that the axle half is a (3rd class) lever.
Where did you get the spring rates though?
Old Apr 14, 2012 | 08:15 PM
Diesel_Brad
Ford................
Old Apr 14, 2012 | 10:19 PM
95f2504x4's Avatar
95f2504x4
ok so really the best bet would be either add-a-leaf or having a new set of springs made. Cause there is a shop in St. louis out by me that actually make there own custom springs.
Old Apr 15, 2012 | 08:02 AM
Diesel_Brad
All they spring shop will do is sell you a new set of springs with a add-a-leaf installed
Old Apr 15, 2012 | 08:31 AM
95f2504x4's Avatar
95f2504x4
Actually this one actually makes there own. I've had two sets made so far through them one for a 93 f250 and one for a 78 f150
DieselCamper
Jun 11, 2016 08:37 AM
dtgl90vt
26
May 16, 2016 05:15 PM
rangernut09011980
May 25, 2015 08:08 AM
97HD4X4
16
Sep 10, 2011 10:24 PM
micksjen
May 19, 2007 12:25 AM
