Dome lights
Old Apr 13, 2012 | 07:36 PM
gfoster82's Avatar
gfoster82
Dome lights
The overhead dome lights of my 01 e350 are flickering on and off when I hit bumps or turn left,any of you guys have this problem with your van?
Old Apr 13, 2012 | 09:11 PM
Bbasso's Avatar
Bbasso
sounds like one of the door pins is faulty, mess with them and see if it makes a difference.
Old Apr 14, 2012 | 07:27 PM
Speicher's Avatar
Speicher
The door switches on the Econoline series are mounted in the hinged side door jam and are self adjusting. A new switch will have the center sleeve pushed completely out, after installing the switch and closing the door the sleeve is pushed in by the door. I have run into this multiple times for whatever reason the switch has been pushed in to far and the light either stays on or comes on intermittently. Inspect all the door switches, they should have roughly the same protrusion. If one were to be pushed in, you can remove the switch and push the center back out and reinstall it.
Old Apr 15, 2012 | 06:52 AM
JWA's Avatar
JWA
Those switches do get pushed in too far on occasion but most times they're simply worn out from frequent opening and closing. Barn door sides and rear switches are different from the fronts, both available most any parts stores since they're so commonly used. IIRC they're about $10 or less each, fronts just a bit more since they come with a new plastic fitting.
Old Apr 18, 2012 | 01:59 AM
gfoster82's Avatar
gfoster82
It was the side door switch,thanks for the help!
randella
Nov 12, 2015 08:34 PM
luvemhot
Jun 11, 2008 11:05 PM
motionmarineaudio
Dec 9, 2007 02:58 PM
DansVan
Aerostar
22
Mar 5, 2007 10:42 PM
alpinearchery
May 31, 2006 05:47 AM
