MSD 6A Ignition Control
Old Oct 13, 2002 | 12:39 PM
geevoor's Avatar
geevoor
Post MSD 6A Ignition Control
[updated:LAST EDITED ON 13-Oct-02 AT 01:40 PM (EST)]How hard is this to install. and what other adjustments will be needed after install or is it a bolt on and go. 97 ford f-250 5.8L
Old Oct 13, 2002 | 02:47 PM
Redneckerson's Avatar
Redneckerson
The wiring is quite simple and straight forward. The box will come with these directions or they can be down loaded from the MSD web page if you buy one used. The longest part always seems to be mounting the unit/ finding the perfect spot away from excess moisture and hiding the wiring after the install. It is pretty much bolt on and go but the matching coil would be a good companion to the 6a box but can be upgraded later. Regards
RSH
Old Oct 13, 2002 | 04:47 PM
slpj's Avatar
slpj
