HIO Silver's Lo-Buck Bumpside Build
#574
#575
Don't go locking your brain up.
Wouldn't a decent hanger prevent any kind of contact from occurring on the passenger side? I mean even though it is temporary everything still looks sanitary and not hacked together. I vote turn downs after the muffler, that's what I chose to run on mine.
The lap band clamps should be here tomorrow and I'm gonna leave it be for now and come back to it. The LBB still needs wiring up of the electric fuel pump, O2 sensor, cooling fans, headlight harnesses, 3g alternator, so it'll give me time to mull it over. Yeah, a decent hanger will prevent movement... it's just not as much clearance as I had hoped for.
I really appreciate all you guys' input on this. It makes me feel like I'm not as alone as I really am while working on the ol' girl. Salud!
#576
'Came in to watch a bit of football and have a cup of coffee...
The Edelbrock ECU provides two low-voltage ground signals at customizable temperatures for each fan speed (or individual fans) so I'm gonna try out this Volvo fan controller. Based on its wiring diagram, only one relay is engaged at any one time (high or low speed) which explains why it only has one power feed.
I merged the Volvo relay harness with the Lincoln Mark VIII plug, fabbed up some weather pack connectors for the fan signal wires, fabbed up an aluminum bracket, and ran the wires. Also ran the fuel pump harness, O2 sensor, alternator harness, and miscellaneous lil stuff.
#578
Yeah, I'm trying to be mindful about how systems are routed. Instead of taping off the ends of the sheathing which always unravel, I'm using small plastic clips that CarCraft magazine noted were used on 90s GM products... I grab them most every time at the salvage yard.
'got tired of looking at boxes of parts in my dining room so I went about assembling the grill, headlights, white turn signal lenses with amber bulbs, and stone shield (valance). I need to order some moulding clips and emblem barrels... there is still the issue with the hood emblems. I think I'm gonna get some 3M reflective yellow vinyl cuz they are faded.
'Installed the LMC headlight harness too. That dang thing BARELY reaches both headlights. Contrary to the pic used in their catalog, the sheathing is black and not yellow.. Thank goodness...I ran it in front of the core support. The middle section is tucked under the valance and then tangent at the radiator opening which has a conveniently located hole in each corner.. it made for a good place to zip-tie the harness and then angle up towards the headlights. The relays part of the harness goes through the core and will mount outboard of the Volvo fan controller. I'm debating with myself if it should have a bracket or simply nut-serted to the core.
All the battery hot feeds (EFI ECU, fan, fuel pump, and headlights) are left long and bundled on the battery tray. I still need to wire up the bumper-mounted driving lights so that's another feed to account for. Heck, I might spring for an Optima since it has side terminals.
Wiring is cerebral and a bit mundane but I'm glad about not being on my knees or back too much... and my fingernails are clean too boot! The guys at work usually comment on Monday mornings about my hands with ground-in grease and dirt. A manicurist would have her work cut out!
The LBB is looking more complete.. it should motivate me more since it looks like it runs. Not yet .. but very soon!
#581
#582
Be methodical! ... with wiring sometimes the "i'll get to it later" bug bites and guess what... we never get back to it.
Me glad too! I've been on it but haven't had quality wrench time in a while. I am almost human again.
I'm just need the hood moulding clips.. $2 each from DC I recall... prolly get the barrels from 'em too.
No side mouldings to speak of on this rig nor the 71. Thank goodness.
#583
#584
#585
Btw, in addition to Delcity.net, Waytek Inc. is another company which sells electrical supplies. Welcome to Waytek
