M5R2 swapped into '83 f100 300 I6...DONE
Just like everyone else has said, nice write up and swap. I do like how you routed your vacuum hose for the Distributor. I was thinking the other day about that, because I have allready bought all my parts for my Dura Spark swap except for the vacuum hoses. I think the whole thing is one sweet setup. I do have a question, where were the hoisting points on the engine or what did you do to support it to remove it?
Like you said in your other post, passion for these trucks exists! and for these Inline 6 engines!! Me I would rather have a new early 1980s Ford truck (if they existed) instead of a 2012 truck!
Last edited by john165; 04-22-2012 at 09:22 AM. Reason: i over looked some info last night
Another old thread resurrection
I went to the jy to get a pedal assembly, shifter, boot and all the other stuff and was successful!
But... before I tear my 81 apart to make the switch, does the pedal assembly bolt right in? The 1987-91 assembly is cast aluminum, and I am just hoping it'll bolt right up.
Thanks,
John
Thanks,
John
Speed Drive Gear on Shaft
This post is 6 years old, but here goes my question about your swap:
I'm putting a '94 M5R2 into an '81 4.9 currently with a C6. You said you purchased the speedo drive gear as a kit, but you didn't mention if you had to replace the whole shaft. Is there a kit that comes with a drive gear to mount to the existing late model shaft, or did you have to replace the shaft, the housing, and obtain the gears?
Thanks for any help, Chris.
First, welcome to FTE!!!
Second, I hate to tell you but he hasn't been on FTE since January of 2012. So, it is highly unlikely you will get a response from him.
So, the best bet is for you to start your own thread and ask questions. With the proper title to the thread you'll get more people joining in to answer your questions.
FirstFord1994
20
03-30-2018 08:17 AM
Clayman302
05-05-2012 08:45 PM
1980StepSide
08-13-2008 05:52 PM
CheeseSteakJim
07-06-2008 08:58 PM
