I belive that is the clip that slides in the rack runners, when you lift the end upward it releases the tension and allows the rack bar to slide, when you push the end peice down it grips the inside of the track and locks bar
Yep, you are correct. Now I just need a part number and someone to order it from.
I am getting rid of my luggage rack bows I'll check and see if the clips are good on mine if you are interested, they are behind a couple things for my boat, but we are firing it up tomorrow so I should be able to get to the bows.
That would be great!!! Send me a PM (We can send PMs on this site, right?) and we can make the arrangements.
