P1211 CEL code
Old Apr 11, 2012 | 11:08 PM
Splatts's Avatar
Splatts
P1211 CEL code
After got my f-6 chip and played around with it. Everytime I lay into it in my 80hp econo setting it throws the same CELL code. Is there anyway to stop this from happening. I mentioned it to Jody and he said its most likely the icp. I just put a new one in about 6 months ago along with an ipr. Don't get me wrong this truck is a totally different monster now!! I roll coal out my new dual 4" stacks in every gear (while in the 60 hp setting) at about 1/4 to 1/2 throttle. Any ideas of how to stop the dang CEL from tripping. Besides not playing with the skinny pedal. Lol
Old Apr 12, 2012 | 12:35 AM
pjwoolw's Avatar
pjwoolw
What HPOP are you running.
Old Apr 12, 2012 | 07:04 AM
Splatts's Avatar
Splatts
Stock with Cali splitshots. Let me guess go bigger is the only way to stop the madness but keep the diesel madness goin. Lol
Old Apr 12, 2012 | 09:03 AM
fordpride's Avatar
fordpride
You can get a bigger HPOP or you can have DP limit your ICP
Old Apr 12, 2012 | 09:32 AM
pjwoolw's Avatar
pjwoolw
Time to get Terminated.
Old Apr 12, 2012 | 10:25 AM
Splatts's Avatar
Splatts
I mentioned it to Jody and didn't get any mention of tuning the icp down. Maybe I should mention it to him? The terminator is pretty tempting!!!!
Old Apr 12, 2012 | 10:54 AM
JamesHajek's Avatar
JamesHajek
Either he can do it in the tuning or you can install an upgraded HPOP... Either way you are taxing the HPO system and it's going to continue to set that light everytime you lay into it and the pump can't supply what's being asked from the tunes...
Old Apr 12, 2012 | 12:36 PM
Splatts's Avatar
Splatts
Is there a possibility that the hpo res is draining down?
Old Apr 12, 2012 | 02:29 PM
Splatts's Avatar
Splatts
I actually had the truck completely lose power and die goin about 60mph. Pulled over and cranked it for a bit. I then unplugged the Icp and then it started right up. Shut it off plugged the icp back in and she has ran fine ever since. Btw the CEL was on previouse to this happening.
Old Apr 12, 2012 | 03:10 PM
Splatts's Avatar
Splatts
If I do upgrade the hpop which is the most cost effective way to go. I know clay has the terminator for about $500 but what about the superduty hpop. 99.5 and newer correct. I checked on eBay and the superduty hpops r spendy!! Junkyard possibly??
Old Apr 12, 2012 | 07:12 PM
JamesHajek's Avatar
JamesHajek
Does your ICP sensor have oil in it? I wonder if just the ICP sensor is screwing with the readings and making your truck act this way...
As far as HPOP res draining down, easy check, just pull the plug on top and stick a straw or toothpick in there to see...
Old Apr 12, 2012 | 07:45 PM
Splatts's Avatar
Splatts
I had it kick on 60 up econo today at 3/4 throttle and 2800 rpms. I will check that icp. It's only 6 months old or so but it can hurt to check. Maybe I will try my old one and see what happens. Thanks for the input.
Old Apr 13, 2012 | 08:52 AM
Splatts's Avatar
Splatts
It did it again and my hpo never dropped below 26-2700 psi. Hmmm. Weird.
Old Apr 13, 2012 | 06:37 PM
Splatts's Avatar
Splatts
If it will ever stop raining maybe I can swap back to my old icp and see what happens. It will throw a cel anytime I half a$$ get into it. Lame lame lame. Ha ha ha the hpo psi isn't dropping super low so I hope it's just that icp I got it off eBay.
Old Apr 13, 2012 | 06:51 PM
fordpride's Avatar
fordpride
What is the ICP % ?
