TPS problem
Old Apr 11, 2012 | 07:03 PM
aa767man's Avatar
aa767man
TPS problem
Well, i trouble shot the TPS after getting the code P0122, TPS test good. Good voltage, signal, and ground.
I guess the next step is to change out the PMC. If i get a salvage one do i have to have it flashed to my truck?
At this point thr expy will not pass inspection.
help
98 expy 5.4
Old Apr 12, 2012 | 12:26 PM
alloro's Avatar
alloro
I wouldn't be so quick to change the PCM without digging into the wiring going to the TPS. I would also take a chance and change the TPS long before changing the PCM.
Old Apr 13, 2012 | 05:57 PM
aa767man's Avatar
aa767man
I did change out the tps on the first run. This time i found a site that walked me through the testing of each wire going to the tps. Only thing i havent done was run continuity from pcm to tps. Looking for a pcm plug chart i need pin 89.
Old Apr 14, 2012 | 09:42 PM
pdqford's Avatar
pdqford
Should be gray with white stripe wire.
Bottom row of connector to pcm, left to right is pin 79 through 104.
1990Fordf150v8
Aug 15, 2024 02:32 PM
Uncle JimBod
Nov 23, 2022 04:31 PM
Hartnett
1997 - 2003 F150
Jul 22, 2003 09:02 PM
BroncoScott
1978 - 1996 Big Bronco
May 17, 2003 08:42 PM
MrPleasant
Feb 17, 2002 11:12 PM
