Oops
Old Apr 10, 2012 | 08:00 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
Originally Posted by 427 fordman
Mine rarely sees over 3k.
And you won't unless you had the rev limiter turned up with your program. 3400 max.
Old Apr 10, 2012 | 08:02 PM
F350-6's Avatar
F350-6
Originally Posted by BlueMule
I was at 42 maybe 43 hundred rpm's and floated a valve and smacked a piston. I guess the rocker arm was the weak link.
That's not a bad weak link to pick. Much better than the valve or piston. As the others have asked, did it bend the pushrod too?
I'm thinking you need more than 910's at those rpm's.
Old Apr 10, 2012 | 08:04 PM
BlueMule's Avatar
BlueMule
Originally Posted by pjwoolw
What happened to the push rod?
Originally Posted by ReBilld
Any bent push rods?
The pushrods are fine
About 5 years ago I put in a set of Diesel Innovations chrome-moly pushrods and Competition Engineering 910 valve springs
427 fordman's Avatar
427 fordman
I don't want to either Scott. I know its never even seen 3400 to find out. I didn't know that though. Thanks.
Old Apr 10, 2012 | 08:06 PM
427 fordman
If you smacked the valve, did you bend it at all?
Old Apr 10, 2012 | 08:14 PM
cookie88's Avatar
cookie88
FTE Emeritus
That is true.. They are cheap and easy. Probably why they are built so weak. A real roller rocker with a different, or even adjustable, ratio could alleviate that problem.... Of course, there would be no room to mount them and still clear the glow plugs.
Whats stiffer than the 910's?
Old Apr 10, 2012 | 08:15 PM
BlueMule's Avatar
BlueMule
Yea I know, a set of beehive springs would be nice. But I just turned 60 and with a bad back and arthritis in my hands there's no way I could lay on top of that engine for that long to do another set of springs. I took me about 4 hours to get it all put back together today and I'm sore.
Old Apr 10, 2012 | 08:26 PM
427 fordman
Must not have bent a valve then if you have it back together already. Glad to hear you're up and running.
Old Apr 10, 2012 | 08:27 PM
ReBilld's Avatar
ReBilld
I'm gonna be pulling the engine from the black/red '97 and over a long period rebuilding it for my crew cab project. I want to compile a list of all the best stuff to put in it and start saving and buying the stuff a little at a time..........so you guys keep talkin, I'm listenin!
Old Apr 10, 2012 | 10:33 PM
BlueMule's Avatar
BlueMule
I've bent pushrods twice in the past and that's why I went with the chromemoly's the last time. I knew by the huffing sound thru the intake that it was something in the valve train but was afraid it had bent a valve or punctured the piston. Valve or piston would have been a bitch to fix because I'd have to jack up the cab just to get the headstuds out and then still have to deal with pulling the head.
I have 2 programs on the chip that have no rev limiter and I've been wanting to try some PHP tunes, this looks like a good reason to get them done.
Old Apr 10, 2012 | 10:48 PM
BuckHammer's Avatar
BuckHammer
...Whats stiffer than the 910's?
There's an inappropriate joke in there somewhere...
Old Apr 10, 2012 | 11:18 PM
oldbird1965's Avatar
oldbird1965
Wow, sounds like a bad back and arthritis in your hands in a minor inconvience to the major stuff that your doing!
  #28
YoungFordAddict66's Avatar
YoungFordAddict66
It's starting to get a lot more frequent. Generally bends a pushrod or two along with it. We can get hardened pushrods, but somebody needs to build a better rocker.......our stockers suck.
Wide Open Performance sells/makes cyro treated rockers for the psd.
Old Apr 11, 2012 | 11:11 AM
  #29
Action4478's Avatar
Action4478
Ooops for sure .. To much Boosht....
Old Apr 11, 2012 | 02:20 PM
  #30
strokin'_tatsch's Avatar
strokin'_tatsch
Something like this???? Pictures courtesy of Jason Hoffman.
Adjustable roller rockers are available through Wipe Out Enterprises for us. From what I understand, part of the assembly is built by Harland Sharp and Wipe Out finishes them up to work for us. Probably not really practical for a daily driver since they probably need to have lash adjusted more often than most would really want to deal with on a DD and they are pricey. Coming in around $1400-1600 IIRC, but come with chromoly pushrods
