I have a 2006 f-150 4x4. the transmsioion started to slip when it would reach 45mph but now it does it from 40-50 mph and it is pretty violent when it does anyone have any ideas
My first idea is to have a professional fix it... Probably not exactly what your looking for but knowing transmissions from racing all they do is get worse and there's no easy fix.
yes you can fell it in the transmission and if you turn the overdrive off it will stop sometomes but other times it still does it if you do pick of the throttle tho all the way down it will stop. the slipping has got so bad now you cant hear the radio and it will shake you out of your seat
