No start, strange fuel smell at start attempt
I'm guessing a bad injector solenoid. Sounds like you're only running on half the cylinders. Could be IDM or wiring related, but I'll guess solenoid first.
If it runs long by giving it a little of the go pedal to get one side hot, then you can diagnose the cold side. Otherwise you get to test both sides. Grab your trusty ohm meter and check the 3rd, 4th, 6th & 7th pin on the connector against the 5th center pin and write down the reading for each injector. When a solenoid goes bad, it often will still read withing spec, but it will be different from the other injectors. The one I diagnosed with a bad solenoid was about 0.5 ohms different from the other 7.
If you find one that's off a bit, unplug that injector and clear the codes. Start the truck and see if it doesn't idle smoother (still with a CEL & miss due to the unplugged injector).
My how the plot thickens...
Got home tonight, in attack mode. HPOP was low, topped it off. Truck still runs bad, but it runs now, now I have CEL and a P1316 DTC. That is what really gets me. Because last night I removed both valve covers and installed the Ford retaining clips and then didn't have a DTC although drivers side was loose. Why the code now, just strange coincidence low HPOP and loose clips (good thing I bought a lottery ticket tonight) after getting to operating temp I checked temps on both manifolds and the drivers side was at approx 140* and the passenger side was at 188* which leads me to believe that I have a dead bank on the drivers side. Could I have shorted out the harness with the loose clip? I arranged for a guy to come over tomorrow night and do a buzz test on her. Any thoughts? Here is a link of how she runs now that I topped off the HPOP.
Lil better - YouTube
UVCH Burned Center Pin
#28
#29
#30
Now that you have a handle on the fix, imagine just how much loot the brotherhood here saved you...what do you think the stealership would have charged you to troubleshoot and repair these issues??? I know it's been a PITA, but now, you have obtained a wealth of knowledge and some extra dough in the wallet to satisfy your future PMS...IMHO...
