What ring gear size do I have?
https://www.ford-trucks.com/forums/1...intenance.html
The axle code in the door jam says "24". According to the graph in the link, I should have a 7.5" gear ring with a 3.73 gear ratio. However when I went to get the parts, all parts store (Autozone, Advanced Auto Parts and Pepboys) state that they only sell the wheel bearings for 8.8" ring gear for 4WD models. This fact is consistent online as well. RockAuto, partsgeek and Autopartwarehose.com all list my van as having a 8.8" ring gear. I can not find any that sells a 7.5" for the 4WD models online either. So I thought for sure that I had the 8.8" ring gear. However, I slid under the back and sure enough I have a 373 75 stamped on the rear differential. So I'm a bit confused as to what bearings I need to use and where to get it.
Also, I went to the local Ford Dealership and the said they can not get parts for my van. Which is odd considering I can still get parts for my 1992 Plymouth Laser.
Timken #s
5707 standard inner race bearing OEM replacement, use if your axle shaft race is ok
TRP1563TAV Kit offset race for damaged race axle shaft.
8660S seal.
even a high school dropout parts counter kid can cross reference Timken
all the AWD Aeros I've looked at had a 7.5 rear end
Autozone lists the Timken 5707 part as the FRONT bearings for this vehicle.
Timken/Axle Shaft Bearing - Front (5707) | 1995 Ford Aerostar 4WD 6 Cylinders X 4.0L EFI | AutoZone.com
They have the TRP1559TV listed as the 8.8" bearing; and
they have the TRP1563TAV listed as the 7.5" bearing for the rears.
Axle Shaft Bearing - Rear | 1995 Ford Aerostar 4WD 6 Cylinders X 4.0L EFI | AutoZone.com
Also, excuse my noob question but what am I looking for on the race? I assume the race is the portion of the shaft that contacts the axle shaft bearing.....
They couldn't find a hole in the ground with their rear end and head stuck in it.
your rear end tag says 7.5 diff and your build sticker has the 7.5" code, believe Ford, they made the damn thing.
Timken knows far more about bearing and correct applications than a corporation ran and staffed by idiots.
the reason Ford used the 7.5 diff in the AWD 4.0l was the fact that the 7.5 spec'd torque load is more than the max. 70% engine output load it carries, remember the the transfer case does a continuous 70/30 power spit rear/front. Ford also had tons of the things built and rusting away for the Aero. Not cost effective planning, no wonder the family is out of the corporation and it's in reality owned by private capital preferred stockholders and their corporate loans of $45 billion that Ford will never pay off.
RockAuto
1995 FORD AEROSTAR 4.0L V6 : Drivetrain : Axle Shaft Bearing Wiki Price
TIMKEN Part # 5707 More Information About this Part 1.4016 in. Bore; 0.698 in. Width One of our most popular parts
