1978 - 1996 Big Bronco
94 bronco starter probs>>
Old Apr 8, 2012 | 04:21 PM
broncoboy71's Avatar
broncoboy71
94 bronco, wont start...just goes clank when you try to turn it over. then wont do anything no lights no nothing no clank even. if you disconnect battery and reconnect it will show battery juice and lights/radio work but goes clank again. after a few times of this it turned over. did it with two different batteries too so its not the battery. Im thinking starter..any thoughts??? just want to be sure before i spend 120$ on starter. thanks
Old Apr 8, 2012 | 11:25 PM
Torky2's Avatar
Torky2
I'm wondering if you've got a bad cable or bad connection. With a good battery charged up, even if the starter motor is stalled and draws real high current, if you turn the key back to RUN, the starter relay on the fender will drop out, opening the circuit to the starter. So lights should go back on if they dimmed out when cranking.
Old Apr 9, 2012 | 12:41 AM
greystreak92's Avatar
greystreak92
Agreed. Check cable connections at the start solenoid on the inner fender, at the starter itself and at the negative connection to the frame and block.
Old Apr 9, 2012 | 09:35 AM
Kemicalburns's Avatar
Kemicalburns
sounds like the solenoid on the fender is bad. they are cheap
Old Apr 9, 2012 | 12:42 PM
Edgethis's Avatar
Edgethis
This is fairly common, its usually the battery terminals and/or wires. They rot internally. I'd pick up a set of new terminals ($6) and see if that fixes it before going further.
Old Apr 9, 2012 | 09:06 PM
critterf1's Avatar
critterf1
Terminals first then check the grounds.
Old Apr 20, 2012 | 10:14 AM
broncoboy71
solenoid on fender wall was bad>>>thanks for all the help
broncoboy71
got another question 94 bronco...will a rear drive shaft off an 89 fit a 94 bronco? c/v joint and u joint are bad>>
Old Apr 20, 2012 | 10:27 AM
broncoboy71
also does it matter if it has 3.55 vs 3.08 gears?
Old Apr 20, 2012 | 01:19 PM
Kemicalburns
if the drive shafts match physically then yes it will work. the key is making sure your pulling from another bronco and that the 89 runs the same tranny as you have. this will ensure proper length.
Old Apr 20, 2012 | 02:05 PM
greystreak92
U-joints are not very difficult to replace. Although, the double-carbon assembly at the front of the rear shaft can be a PITA without at least a vice to hold things while you work.
DiscardedFrog66
Sep 25, 2019 09:28 AM
Treay Turner
22
Oct 6, 2017 11:00 PM
joey2fords
May 26, 2014 10:18 PM
fordka
Nov 27, 2013 05:50 PM
greenf150
Jan 20, 2005 11:06 PM
