1980 F150 steering question please help
04-08-2012, 02:32 PM
on
My rag joint ripped and came apart, and I been trying to get it back together and I think I finally got it, I attached a picture and was wondering if someone can tell me if I did it the rite way or the wrong way, thanks for your help.
IMAG0137.jpg picture by Citykilla - Photobucket
04-08-2012, 03:01 PM
on
not sure if it's just the picture or not but it looks to be significantly off center between the 2 shafts.
When you turn the wheel...does it seem to turn straight or does it "wobble"?
04-08-2012, 03:02 PM
on
And btw...welcome to the forum!!
04-08-2012, 03:04 PM
It's hard to see for certain in the picture, but the lockwasher on the RH side (of the pic) doesn't look to be seated squarely beneath the nut?
04-08-2012, 03:15 PM
on
Quote:
Originally Posted by
82f100460
I have not drove it yet, I was told there is a metal piece that came stuck with it but it must of broke some guy said you really don't need it.
04-08-2012, 03:16 PM
on
04-08-2012, 03:27 PM
on
jimmyhighrider
Hard to say with the picture what all you have in there. Short of buying a whole new peice...if you have the 2 connected then it may just work.
Although it does seem to be off centerline.
It's a matter of how long it will last. My concern would be if it fails again while heading down the highway.
04-08-2012, 04:01 PM
on
82f100460
I bought a new rag joint, that's it. I didn't know it can be off center I just thought you slipped it on and tightened it down.
04-08-2012, 04:04 PM
on
Would any body happen to have a picture of theirs?
04-08-2012, 04:35 PM
This is what my 1981 F350 looks like.
Looks like somebody replaced it once...
04-08-2012, 04:55 PM
on
jimmyhighrider
Ok...didn't realize you had replaced it. Thought your were just trying to repair it.
Maybe it's just the picture...the 2 halves seem to be lined up but seems to be off center from the steering gear.
anyway you can get some better pictures?
04-08-2012, 05:05 PM
on
ctubutis
Thanks. Wait are your bolts pointing upward instead of downward?
04-08-2012, 05:06 PM
on
82f100460
Yea sorry I didn't explain it well enough. I can get pictures in a little while.
04-08-2012, 05:08 PM
on
yep...that's they way it's supposed to be
04-08-2012, 05:38 PM
on
