Fuel not circulating proper
Old Apr 7, 2012 | 03:05 PM
QLWest's Avatar
QLWest
Question Fuel not circulating proper
I just bought and installed a new fuel pump on my 1987 f-150 305 5.0 and still no fuel is reaching the engine.
The truck was cranking just fine then I let it sit for a year and now it doesn't crank?
Old Apr 7, 2012 | 03:43 PM
CletusSnow's Avatar
CletusSnow
Welcome. Do you know if your pump is running? or even getting power? Do you hear it running, wont be very loud but still make noise, also your rig has multiple pumps, one in each tank (low pressure) and a frame rail mounted one (high pressure). You can ground I believe its pin 6 of the diagnostic harness to manually trigger the pump relay and power all the pumps, and see if you get and fuel then. I'm sure a more senior member will chime in shortly with a diagram of the connector and which pin to ground. Do you have multiple tanks, if so does it get fuel from either one? Which of the 3 pumps did you replace?
Old Apr 7, 2012 | 05:45 PM
QLWest's Avatar
QLWest
Thanks Cletus Snow, I didn't see but one big long fuel tank up under and the fuel pump was connected on top which ran inside the tank. I bought a cheaper fuel pump and filter from auto zone and rebuilt it around the old connectors. Should I do a do a diagnostic with an electric light to see if anythings burned or corroded?
Old Apr 7, 2012 | 05:55 PM
CletusSnow's Avatar
CletusSnow
First test to see if you're getting electricity to the pump, at the tank connector, if you are, then pull your pump out and make sure you spliced the connections properly, if its not right, make it right. What led you to believe it was the fuel pump, or even this pump? If you have two fuel fillers, you have 2 tanks, the long drivers side mounted one and one between the frame rails, behind the rear axle, and above the spare tire, just would hate for the switch to be set to draw off the rear tank if you're working with the front...
Old Apr 7, 2012 | 06:06 PM
QLWest's Avatar
QLWest
I never check the one above the rear tire, only the one above the drive shaft. And I have the fuel switch on the rear tank instead of the front tank.
Old Apr 7, 2012 | 06:09 PM
CletusSnow's Avatar
CletusSnow
Yeah, if the switch is on the rear tank, the front wont pump, or be drawn from.
Old Apr 7, 2012 | 11:24 PM
QLWest's Avatar
QLWest
Does each tank has its own fuel pump?
Old Apr 7, 2012 | 11:30 PM
CletusSnow's Avatar
CletusSnow
An 87 has 3 pumps, one in each tank (low pressure), sometimes called a lift pump, and then another mounted on the frame rail around the fuel filter, (high pressure). Why do you ask? Whats going on?
Old Apr 8, 2012 | 09:08 AM
subford's Avatar
subford
Your fuel system:
The plug to ground pin #6 to test the HP pump and the selected pump:
Old Apr 10, 2012 | 12:04 AM
QLWest's Avatar
QLWest
Thanks Subford, I seen that plug under the hood and its disconnected. I couldn't find what it was to connected too?
Old Apr 10, 2012 | 06:45 AM
jroehl's Avatar
jroehl
It's not meant to be connected to anything other than test devices.
Jason
Old Apr 10, 2012 | 07:34 AM
klricks's Avatar
klricks
Check the link in my signature for fuel system info and OBD1 test connector info.
Old Apr 10, 2012 | 11:13 AM
QLWest's Avatar
QLWest
Thanks guys Ill post when I get results.
Coverbrooke
Apr 13, 2012 06:54 AM
James Rutley
Aerostar
Jun 11, 2011 11:33 AM
tinman52
Oct 19, 2010 11:13 AM
1big88
Oct 27, 2004 07:18 PM
MrPleasant
Aug 28, 2001 08:18 AM
