WORK DONE CHANGED WIRES-NEW PLUGS-NEW CAP- NEW ROTOR-REMOVED CAT AND INSTALLED DIRECT PIPE-ALSO INSTALLED MODULE ON THE SIDE WALL OF DRIVERS SIDE
PROBLEM ?
WARMED UP TRUCK IN DRIVE WAY- CLIMBED IN TO DRIVE- WENT DOWN ROAD AND TRUCK STARTED TO BOG DOWN -TURNED AROUND DROVE BACK INTO DRIVE WAY AND THE TRUCK HASN'T STARTED SINCE ?
I PUT IN 5 CONTAINERS OF DRY GAS IN 1/4 OF A TANK OF GAS
GETTING GAS TO THE INJECTORS
WHEN WE TRY TO START TRUCK YOU CAN SMELL THE GAS COMING OUT 0F THE PORTS AND WE ALSO USED STARTING FLUID AND THE TRUCK DID NOT START
GETTING A GOOD SPARK
Anybody know what could be wrong here???? Tried everything
