Exhaust advice
Old Apr 2, 2012 | 01:48 PM
Silvabullet78's Avatar
Silvabullet78
Exhaust advice
Well now that i got my 78 F250 running like a champ, i need some advice on exhaust...i am looking to go to true duels i have headman headers that i need to install...what do you guys recommend for the rest? i have had alot of people say magnaflow...i am going to cam the truck in about a month so i want it to sound as good as possible...i am also looking at installing the system myself...so is it cheaper/easier to just buy the set up online...and is there possibly other companies that make exhaust sytems that are cheaper in price but not performance?
and lastly i was thinking about dumping the exhaust right in front of the rear tires ....anyone have this done? does it look good/sound good???
Old Apr 2, 2012 | 03:26 PM
PowerstrokeRyan's Avatar
PowerstrokeRyan
I have hooker headers to 2 1/4 piping then put glasspacks (24") below the cab. True duals. Have them at a 90 in the rear sound great. Alittle more bark then when i had them in front of the wheel.
Old Apr 2, 2012 | 03:54 PM
PEARLOFTHEDESERT's Avatar
PEARLOFTHEDESERT
its exhaust season or something. im sitting on some flowtech headers just waiting to instal and was going to do a true dual and have a 90 degree straight down pipe behind the cab. not sure on the mufflers yet. thinking about the largest CB glasspack i can find would do but want a deep tone..
Old Apr 2, 2012 | 05:34 PM
Silvabullet78
I want a deep throaty tone, esp once i throw the cam i wnt a deep muscle sound! I havent even looked into glasspacks, i will prolly go with some of hose cuz they are way cheaper and most say they give you a good sound
Old Apr 2, 2012 | 06:07 PM
PowerstrokeRyan
Glasspack is a bark if you want a cheap good deep sound get a cherry bomb turbo muffler. Not as loud but a deep tone.
Old Apr 2, 2012 | 06:35 PM
Blue and White's Avatar
Blue and White
When I do mine, I plan to use the Hooker dual kit. They offer one version for manifolds and another for headers. 2 1/4 mandrel bent aluminized tubing and you pick the turbo muffler of your choice. Exit is behind the right rear wheel. Cost is reasonable through Summit.
I wouldn't mind 2 1/2" pipes but I figure the mandrel bent 2 1/4 is at lest as good as an exhaust shop "crimp bent" 2 1/2 and its twice the capacity of OE.
Old Apr 2, 2012 | 07:33 PM
HIO Silver's Avatar
HIO Silver
2.25 or 2.50-inch tubing and mufflers of your choice. If you can weld, then I recommend getting a mandrel bent tubing kit from Jegs' or Summit. ..depending on mufflers, you can get 'er done for as little as $260 or less.
Sometimes ya can find newish Flows at the JY... worth a thought.
Hedmans, 2.5-inch tubing, and Moroso Spiral Flows - Mine dump in front of the passenger side rear tire:
<embed width="440" height="420" type="application/x-shockwave-flash" src="http://v5.tinypic.com/player.swf?file=34gpukh&s=5">
kyle1979ford
26
Aug 14, 2013 10:29 PM
XxWINxX94
15
Sep 24, 2011 12:58 PM
76fordtruck
Exhaust Systems
Jan 29, 2005 11:22 AM
Firefighter8-1
Exhaust Systems
Jul 29, 2004 08:11 PM
79_ford_400_guy
Mar 21, 2002 07:19 PM
