Fog Lights
Old Apr 2, 2012 | 10:16 AM
Regulator1988's Avatar
Regulator1988
Fog Lights
My truck didn't come with Fog lights how hard is it to install
Old Apr 2, 2012 | 10:26 AM
zhilton's Avatar
zhilton
Not sure if all the wiring would be there if your wanting to run factory lights. Pretty sure you'd have to swap the light switch on the left side of the dash and need to check to see if the harness is there by the tranny cooler for the lights.
Old Apr 2, 2012 | 11:33 AM
Regulator1988
The headlight switch?
Old Apr 2, 2012 | 11:42 AM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
Yes, to activate factory fogs you pull the headlight switch out after turning it to running lights or low beams. The switch is a separate assembly in the dash cover that has to be replaced if you want full-factory integration.
You could always just bolt in a pair of factory fogs and wire a relay to a toggle in the cab, it would probably be cheaper/easier, just not factory-clean inside the cab.
Old Apr 2, 2012 | 12:36 PM
Regulator1988
As long as they come on I'll be on
Old Apr 2, 2012 | 06:08 PM
zhilton's Avatar
zhilton
You could do what I'm doing, use an upfitter type of switch for it. Since I drive an '04 (upfitters weren't available until '05 MY) I installed a F650 dash from RiffRaff and have one of the six switches set up for the fog lights. I'm not a fan of the factory fog light switch.
Riffraff Diesel: Riffraff Custom Auto Dash Kit - OUT OF STOCK
Technologiq
Apr 2, 2014 12:54 AM
cecilt
Feb 3, 2011 10:06 AM
ron01sd
Jan 6, 2008 11:29 PM
PAPPYBALL
Escape & Escape Hybrid
Dec 15, 2006 06:24 PM
4x4_EB_Explorer
Electrical Systems/Wiring
Mar 16, 2002 05:45 PM
