1978 - 1996 Big Bronco
turbo kit
Old Apr 2, 2012 | 02:03 AM
bluegoose95401's Avatar
bluegoose95401
turbo kit
my Buddie has a 78 or 79 bronco with the 351m/400 motor we found a kid with a turbo kit for a 351 w just wondering if the exhaust manifolds will match i know nothing about the 351 m or 400 block
Old Apr 2, 2012 | 02:17 AM
justin Wallace's Avatar
justin Wallace
nope. I wouldn't slap a turbo on a motor without making sure the internals were built anyways. There are a lot of turbo kits on ebay that are generic and will probably not do much for you.
Do you have a picture or info on the turbo kit?
Old Apr 2, 2012 | 02:25 AM
bluegoose95401
ya its the jegs turbo kit for a mustang with a 351 swap
Old Apr 2, 2012 | 02:26 AM
GruesomeJeans's Avatar
GruesomeJeans
Also as a fellow 78 owner, i wouldn't slap a turbo on it anyways. It has plenty of power on it's own unless you plan to race it. Another bad idea. They have the power to move you up a muddy hill you just need the right tires for the job. A turbo i doubt would help much. And no thy wouldn't match up. The 351/400 M blocks were different from Windsor blocks.
Old Apr 2, 2012 | 03:20 PM
bluegoose95401
cool thanks for the info ill relay it to my buddie with the truck
Old Apr 2, 2012 | 05:01 PM
Edgethis's Avatar
Edgethis
I believe that the 351C may work on a 351M with a bit of work if they have one.
Old Oct 22, 2014 | 02:31 PM
Thunderhorn's Avatar
Thunderhorn
I will be completely building a 400 eventually and am interested in putting a turbo on it. Ive read a lot about why this is a bad idea but have seen almost all of it is just "bad idea" or "just put in a 460 instead" I want to know WHY it isn't a good idea and am not interested in swapping to a different engine.
Old Oct 22, 2014 | 09:25 PM
Raleigh1's Avatar
Raleigh1
The 400 is actually a good motor to boost, it has low compression and reasonably large internal components.
I think the problems start when you throw too much boost at an old tired engine with crappy timing and low oil pressure.
You first have to address the timing issue, this is easy enough with a new straight up timing set. The oil pressure is another issue all together, this requires a full rebuild.
I plan to boost my Bronco and I am building the engine with that goal in mind. I will be running 5 to 6 psi tops, any more than that would require forged rods and pistons.
Old Oct 25, 2014 | 01:03 PM
Thunderhorn
So since I do plan on a rebuild anyway I don't see any reason not too. So are you planning on boosting your/wife's 79? how's that going btw? haven't seen any progress lately.
Old Oct 27, 2014 | 04:26 AM
GruesomeJeans
I'd recommend reading up on the 351M cooling issues. The back 2 cylinders don't get very cool cooling due to the dry intake. I forget the name but there is a thermostat that is specifically made to help that issue. Mine is old and tired so I'm not overly concerned, and it doesn't get warm anymore, it sits. But anyway, if you're going to boost it I'm sure you'll be running it hard, don't want that purty engine to get hurt.
ThaChosenTLJ
Supercharger, Turbocharger, Nitrous Oxide & Water/Methanol Injection
Jan 1, 2008 08:31 PM
74shane
Sep 17, 2005 01:26 PM
mustange70
Feb 1, 2002 09:39 PM
