98 steering clunk
Old Mar 31, 2012 | 12:22 PM
0gers's Avatar
0gers
98 steering clunk
Hi Y’all.
I’ve got a 98 RWD 5.4 with about 170,000 miles. It recently developed a loud clunk from the steering while parking. It only happens at low speeds and only when changing direction from turning left to turning right. It only happens sometimes and it seems to be worse in reverse than going forward……
<O</O
I climbed underneath this morning and everything looks pretty tight including:
<O</O
- Tie rod ends<O</O
- Sway bar links<O</O
- Ball joints
<O</O
I gave the whole steering a good ole yank back and forth and there doesn’t seem to be any play in the system.
<O</O
It’s also probably worth mentioning that about 18 months ago I replaced all the ball joints, bearings, sway bar links, tie rod ends etc. All the stuff I replaced seems pretty tight, but I have neglected to grease any of it since I did the replacement.
<O</O
<O</O
Any bright ideas? I’m drawing a blank here!?<O</O
Old Mar 31, 2012 | 01:23 PM
critterf1's Avatar
critterf1
Have somebody turn the wheel as you watch the components. Pay special attention to the rack mounts.
Old Mar 31, 2012 | 08:49 PM
pdqford's Avatar
pdqford
Originally Posted by 0gers
<O</O
<O</O
Did you check (and have you been greasing) the idler arm?
Nudnik
155
Mar 21, 2014 02:54 PM
david campbell
1997 - 2003 F150
Jan 13, 2014 01:30 PM
DRRXR
55
Jan 21, 2012 04:31 PM
corey_small
15
Aug 2, 2011 06:17 PM
RA12625
Dec 3, 2010 09:05 AM
