Why is LTFT so high?
Old Mar 31, 2012 | 06:21 AM
Ted928's Avatar
Ted928
Truck runs fine and there are no codes but I plugged my new OBDII logger in and learned that my LTFT is nice and low at idle (+1%) but increases to a max of +20% as load increases. It is +10% at cruise. STFT bounces around zero as it should. Both banks are very similar. When I plot air flow rate from MAF vs. from MAP I see a correlation but a lot of scatter. I didn't think this truck had a MAP.
Truck is a 2005 5.4L, 50kmiles, new plugs and fuel filter at 30Kmiles.
Old Mar 31, 2012 | 10:27 AM
70f100longbed's Avatar
70f100longbed
Try cleaning the MAF with MAF cleaner, don't use anything else. Could have a dirty wire.
Old Mar 31, 2012 | 08:25 PM
Ted928's Avatar
Ted928
Good suggestion. Bought some MAF cleaner,removed and cleaned the MAF - no change.
Any other ideas? Is there something else I should log?
Thanks
Old Mar 31, 2012 | 10:16 PM
70f100longbed
Are there any codes? Do both long trims read high or just one? Can you see a graph of the O2 sensors and if so do they switch smoothly or jagged? They should look like nice smooth rolling hills.
Old Dec 27, 2017 | 01:32 PM
Ted928's Avatar
Ted928
What should the LTFT be at cruise and while accelerating? Has anyone measured theirs?
Old Dec 27, 2017 | 05:48 PM
pdqford's Avatar
pdqford
It can be at whatever it takes to keep the fuel mixture optimized without setting a code. It will be different depending on air temp, coolant temp, fuel pump pressure, fuel filter resistance, injector condiction, etc, etc.
Ford typically runs a 3 x 3 grid for fuel trims. (Think of the vertical cells representing low/medium/high engine load and the horizontal cells representing low/medium/high engine rpm.) The scan tool displays the fuel trim of the cell the engine is currently operating in. It is used to minimize the engine variable that change with age/miles.
Thedonutninja
Oct 14, 2017 03:30 PM
Blaine Lakusta
Modular V8 (4.6L, 5.4L)
Sep 1, 2017 09:01 AM
Pocketlint
Jul 9, 2017 06:36 AM
Judd944
1997 - 2003 F150
46
Oct 7, 2011 11:22 PM
japjb1
1997 - 2003 F150
Jun 25, 2006 04:24 AM
