Cheaper A/C system?
Old Mar 31, 2012 | 09:05 AM
james G. phillips's Avatar
james G. phillips
Reed51, I have an old Mark IV under dash unit that has mounts you bolt to the floor. It could probably be mounted under the dash as well. $100.00 PM me if interested.
Old Mar 31, 2012 | 09:15 AM
oldmerc's Avatar
oldmerc
oldmerc
Really guys you have lost focus on whats important to cool off just open the window tan your arm . Whats real important is a good heater .
Old Mar 31, 2012 | 09:37 AM
49willard's Avatar
49willard
Originally Posted by Damifiknow
Anybody install a compressor on a 239 flatty?
I headed down that road on a 38 Woodie that I had, but never got there. PM me if interested in a mount for a Sanden compressor.
Old Mar 31, 2012 | 09:21 PM
das54's Avatar
das54
I'm thinking I might try to fit a rear A/c out of a Astro van under the seat but first I need to finish the fenders and a ton of other things.
Old Apr 1, 2012 | 12:12 AM
BigB9000's Avatar
BigB9000
Small, compact, Self contained unit (well, 2 lines running to it)
Not a bad idea.
Another option would be one from a suburban.
Here is what I plan on going with:
I dont know what its from though.
Old Apr 1, 2012 | 12:35 PM
reed1951's Avatar
reed1951
I really like the kit that I set the link to before as it is a A/C and heater but it just has the 4 vents in the front of it which means there isn't a way to run duct up to the defrost for the windshield. So I think that would mean I would need to keep my original heater as it has the duct/hose that runs up to defrost the windshield. The original heater worked great and would burn me out of the truck going to work on a cold day.
I asked a question about the that kit on ebay and after he asnwered my question the guy offered it to me for even lower price...MAN! I wish I had something to sell to go ahead and buy it but you guys know how that goes LOL
Old Apr 1, 2012 | 02:32 PM
tacson's Avatar
tacson
Hello Reed,
I know the width of a 53-56 is a little wider than an F1 but I swapped out this OLD AIR Unit
for this Underdash AC unit.
Put the stock heater with defrost back in and the setup works good. The unit you posted looks like it should do wonders in your cab. This unit cools my cab very well and my cab is not LEXUS car airtight by any means. I wish you the best in getting AC in your cab. It helps make the driving more pleasurable.
Old Apr 1, 2012 | 02:52 PM
reed1951's Avatar
reed1951
Thanks tacson, that's what I'm gonna wind up doin then. It really helps when you guys post pics and discuss what y'all have tried I really appreciate it! Driving my truck as much as possible is my goal when it is done/drivable and an A/C setup will help that out tremendously.
Old Apr 1, 2012 | 02:55 PM
tacson's Avatar
tacson
No problem. When your finances allow get that puppy and put it in there. Here is a different view of the Underdash Unit I got
Old Aug 1, 2012 | 08:28 PM
calorchard's Avatar
calorchard
UNIVERSAL AIR CONDITIONING KIT w/ HEATER- UNDERDASH
Anyone try this unit?? I bought the mid50 power steering kit and was thinking.....if I am going to put on a power steering pump why not a AC also...
Old Aug 1, 2012 | 10:52 PM
BigB9000's Avatar
BigB9000
Right by my house too!
Too bad I'm nowhere near needing this.
Old Aug 2, 2012 | 12:09 AM
5wests's Avatar
5wests
What's an "air conditioner"?
Old Aug 2, 2012 | 12:45 AM
  #28
ZFLASH's Avatar
ZFLASH
Originally Posted by ben73058
Hey Reed,
I think the Vintage Air price for our '48-'52 trucks is higher
than that $1,300 number. I used their "mini" option - stupidly expensive.
It's also overkill with our cab size - the lowest setting will freeze important
body parts. There has to be a good salvage A/C solution - It's amazing all the effort put into the different salvage front end solutions. The aftermarket A/C stuff is the same price as decent IFS.
Good luck over there Reed - A/C isn't optional in Texas.
Ben in Austin
Come on now Ben, we don't need no stupid a/c in Texas. It just kills my already sorry gas mileage and takes away the nostalgic feel of a good 'ol farm truck . Now if I can just get that hole in my floor board covered so the hot air quits blowing in, I'd be golden. No top on the Vette either . L8R ZFLASH
Old Aug 2, 2012 | 12:48 PM
  #29
Jeff and Nicolle's Avatar
Jeff and Nicolle
I am going to run my compressor, so I can get a drive belt easily. I am subscribed on this one. I would like to come up with a reasonable solution also. I would think (there I go again) that you could utilize a system from a salvage yard, but I am far from needing this. I see it as "NOT AN OPTION" I will have a/c in mine. and it won't be no $1300 dollar setup.
Some of these under dash units look like a pretty easy solution though.
Back in 1989, I worked for U_HAUL as a Mobile Repair Unit. They set me up in a '78-'79 F-350 14' box truck. it was all decked out like a mobile garage. Anyay, it had an underdash unit. It looked really cheesy to me at first glance, but it froze you out!
I took a college course on a/c (before R-134a) because I knew nothing about it. Well I still don't know alot, but at least I can recharge my own a/c and not worry about a can blowing up in my hands.
At least they have different connections for the hi/low sides now.
I still wrap the cans with a an old towel for safety.
when I took the a/c class, they showed some nasty videos of freon cans blowing up, they were connected to the hi pressure side. Not good at all..
Old Aug 2, 2012 | 02:05 PM
  #30
ChuckRob's Avatar
ChuckRob
I also am subscribed on this one. I would like to put air in the truck but the budget is a little tight right now.
palehorse13
15
Aug 3, 2017 10:51 AM
hcole125
Nov 12, 2012 01:07 PM
WpnEng
16
Sep 3, 2007 09:34 PM
mark460
Aug 8, 2003 09:54 AM
stephenw
Jul 31, 2001 03:15 PM
