Part swapping question
Old Mar 29, 2012 | 08:54 PM
Jaime74656's Avatar
Jaime74656
Ok, I know what year ranges will fit the truck I have (1995 F150 XLT) but thats not a problem, what I want to know (after some checking, and test fitting and some "well that isn't working" moments at the junk yard) will any light assy from the F250/350+ (92-96/97) fit on the F150?
When I was messing in the parts yard I tested one set of headlights from a F250 on to a F150 and they wouldn't fit properly, they were close...so is this a no they won't or was that just more likely a fluke thing where the part(s) may have been bent/damaged? (truck I pulled off was rear impact while the test truck looked to have had a bent front end that may have been rebent back to "normal" so I assume it was a bent frame related issue on this...anyways thanks for the help!
Old Mar 29, 2012 | 09:24 PM
Encho's Avatar
Encho
The Southernmost Mod
They should be a direct swap Jaime, if you doubt it try a search for replacements, you'll see they advertise them for all the models.
Old Mar 29, 2012 | 09:56 PM
minnesotafisherman's Avatar
minnesotafisherman
Yep. 92-96 F150/250/350 and 97 F250/F350 headlight assemblies are all identical.
Old Mar 29, 2012 | 10:34 PM
Jaime74656's Avatar
Jaime74656
ok cool thats what i was thinking so it musta been due to the frame or something being bent I bet, thanks guys/gals
Old Mar 29, 2012 | 10:40 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
along with the 92-97 F-Super Duty (f450) too.
Old Mar 29, 2012 | 10:52 PM
Jaime74656's Avatar
Jaime74656
cool, heres the lamps im lookin at, anyone have any experiences with them?
92-96 FORD F150/F250/BRONCO EURO CRYSTAL HEADLIGHT PAIR | eBay
eBay - New & used electronics, cars, apparel, collectibles, sporting goods & more at low prices
Old Mar 29, 2012 | 11:10 PM
minnesotafisherman
Just forgot, that's all.
Old Apr 3, 2012 | 12:17 PM
Jaime74656's Avatar
Jaime74656
ok guys (and gals) im about to order me a set of new lamps, are these any good, they say they will fit so just want your alls second on them, im gonna go with the "euro" style as thats what I already have on the corners so I like it all to match
Old Apr 3, 2012 | 12:23 PM
thechief66's Avatar
thechief66
$32? For the pair??
That seems awfully cheap.....
If you buy, let us know if they're any good.
Old Apr 3, 2012 | 12:55 PM
minnesotafisherman
Some people around the forums here have went with those and they say that they are better at night than the stock Ford grid pattern headlights. Plus, they look better.
I would get them if I were you.
Old Apr 3, 2012 | 02:10 PM
Jaime74656's Avatar
Jaime74656
Originally Posted by thechief66
$32? For the pair??
Don't worry will do!! bought them (well my dad did as my truck needs better non yellow, and he wanted to make sure the truck is safe at night while driving) so yea should have them by say next week (i hope)
Done, just went ahead with the order after my dad gave the green light to get them (he wanted to pay for them)
Old Apr 3, 2012 | 09:57 PM
FORDF250HDXLT
they're cheap.but they look good when installed,and your going to be floored at how much brighter the lights are at night.way safer than old yellowed plastic housings.
i went with depo.but they're just twianees cheapies too.
rather than straining your eyes and hunting for the road,you'll actually enjoy driving at night with white, clear, safe beams!
Old Apr 4, 2012 | 04:09 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
The only thing I feel I should add is to make sure they are adjusted so you aren't blinding every oncoming driver.
Obviously they aren't approved for road use here in the U.S.
***ATTENTION: DISCLAIMER!!***
This item is produced for off-road or show purpose only. This item is not suitable for regular driving. User must follow the direction given and any misuse of this product is at his/her own risk. The Manufacturer, Distributor, and retailer will not be held responsible for using this item other than specified above.
Old Apr 8, 2012 | 09:55 PM
Jaime74656's Avatar
Jaime74656
Yup I know that ard, thanks for the info, I will be sure to aim them properly before going out on the road at night as well, don't worry about that, safety is #1 to me and I would never want to intentionally do any thing that might compromise anyones safety!! not good...
anyways I did order them and I got them last friday (yay) 4/6/2012 so once the corners arrive I will be putting these things on and see how it all looks, and admire the truck more again thanks every one for all the valuable info I have learnd and gotten to help me fix and work on my truck!!
Old Apr 9, 2012 | 03:57 PM
Red460's Avatar
Red460
So thats what you've been up too...I'm getting smoked for mine headlights/corners and a HID kit. Hopefully will see a pic of yours soon.
