Installing Steering Damper (stabilizer)
Old Mar 29, 2012 | 06:32 PM
Tuxedo Scorpion's Avatar
Tuxedo Scorpion
ok so ive read and seen some stuff about replacing the steering damper with products such as the bilstein 5100 series. all the posts ive seen include a BFH and lube. I often resort to those methods only after ever other method has been exhausted, as im not inclined to force things.
Obviously there is pressure (shear load i think) on the fitting.
Im curious if it is possible to relieve the pressure by turning the wheel to one side or the other.
Anyone try this?
Old Mar 29, 2012 | 07:59 PM
ruschejj's Avatar
ruschejj
Gear puller and a few taps with the brass hammer. It's pretty easy as long as you use a saturating oil and go easy with the pressure, tap and turn.
Old Mar 29, 2012 | 09:29 PM
2000silverbullet's Avatar
2000silverbullet
Super quick job with huge returns. Your truck is still new enough that things aren't going to be rusted/clobbered together. Just gotta get in there and do it.
Old Mar 29, 2012 | 09:31 PM
Tuxedo Scorpion
Truck hasnt even left the factory yet lol. Any day now tho. And already have my bilstein 5100s waiting
Old Mar 29, 2012 | 09:35 PM
2000silverbullet
Should be new enough then! Lol. My wife was getting mad that my floormats and amp steps were piled up in the dining room....
Old Mar 29, 2012 | 09:41 PM
Tuxedo Scorpion
Well im on extended leave and and my stuff is piling up in a hotel room. Lol. I actually ordered the truck out here not at home...better deal and more for my trade in too
Old Mar 30, 2012 | 08:09 AM
jlalanas's Avatar
jlalanas
I use a pickle fork (ball joint separator) and a small sledge. I leave the nut on a couple turns for the end of the stabilizer doesnt pop out and hit anything on the bottom of the engine.
Old Mar 30, 2012 | 08:12 AM
Tuxedo Scorpion
So what i gather is there is pressure on the connection no matter what. Im guessing its not a interference fit, meaning pressed in.
Old Mar 30, 2012 | 08:37 AM
jlalanas's Avatar
jlalanas
It's a tapered bolt so when the nut it tightened up, it pulls the taper into the hole in the steering link.
If anyone is going to use the pickle fork to remove the Bilstein 7100 bracket, be careful. You can break the weld holding on the stud.....i've done it.
Old Mar 30, 2012 | 10:11 AM
CA-F250's Avatar
CA-F250
which stabilizer to buy
Sorry guys, I am a little confused. I have seen the bilstien 5100 steering stabilizer / dampner and also the!bilstien 7100. Is one a newer generation or a completely different. which one are you buying.
Old Mar 30, 2012 | 10:14 AM
Tuxedo Scorpion
Im doin the 5100 as my shocks are 5100s
Old Mar 30, 2012 | 10:36 AM
CA-F250's Avatar
CA-F250
bilstein 5100 stabilizer
Is it the bilstein steering stabilizer / dampner 5100 # 24-158930. 4 wheel parts has them $79. Sounds like they are pretty easy to install.
Old Mar 30, 2012 | 12:36 PM
CA-F250's Avatar
CA-F250
Sorry I believe I post the wrong part number. the above mention is for a 2 wheel drive. According to the guy at 4 wheel parts (online) the one for 4 wheel drive is part # 24-196284 also for the same price. I also double checked it with the bilstein website. Is this the one you guys ordered.
Thanks
Old Mar 30, 2012 | 07:57 PM
Shepardsonp's Avatar
Shepardsonp
I also have the Bilstein 5100 shocks but am putting the Rancho DS on my truck. I have a 2" leveling kit which is why. Without the leveling kit, you don't have enough clearence.
Old Mar 30, 2012 | 11:40 PM
stltikn's Avatar
stltikn
We have had great success with vibrating/hammering all around the female portion of the tapered stud joint. It will take more than one rap. Install the nut with a few threads if the male portion can damage something when it falls out Never ever hammer on the threaded shaft end with or without a nut installed. We don't use pickle forks. When installing the new or replacing the old male taper, insure both the male and female portions are clean and dry. Do NOT lubricate a tapered joint connection.
