Go fast stuff
Old Mar 28, 2012 | 11:32 AM
Regulator1988's Avatar
Regulator1988
Go fast stuff
Hey guys I was just wondering about a turbo timer and a programmer or if there was a programmer that had a timer built in
Old Mar 28, 2012 | 01:39 PM
Dieselpop's Avatar
Dieselpop
With a 6.0 you need gauges and the best one and looks cool is the Edge Insight CTS plus it is expandable and you can add a turbo timer, but i would not get Edge tunes because they are hard on the trans.
Edge Inisight CTS
Things you can add down the line like turbo timer & back up Monitor & fuel pressure
The Edge accessory system (EAS) was created with future expandability in mind Product Code: EDG98603
http://www.toyhauleradventures.com/2011/04/edge-products-cts-update-turbo-timer-install/ Product Code: EDG98604
http://www.toyhauleradventures.com/2011/02/insight-cts-monitor-by-edge-products/
Ford Powerstroke 6.0L fuel pressure monitor and low pressure fix. | Toy Hauler Adventures
Free Shipping
For tunes the only one for a 6.0
SCT Xcallibrator3 W/ Custom Tunes By Innovative Diesel or Matt at Gearhead, there are others also.
pop
Old Mar 28, 2012 | 03:20 PM
Regulator1988
Edge Inisight CTS
Free Shipping
pop
do i need to get the EGT probe
Old Mar 28, 2012 | 03:46 PM
Regulator1988
so i need that and the x3?
Old Mar 28, 2012 | 04:53 PM
Dieselpop's Avatar
Dieselpop
You will need this if you want to add on to the Edge CTS
EAS Starter Kit w/ EGT Cable for CS and CTS (expandable)
FirstCoastDieselPerformance.com -- Your Source For Powerstroke Performance
Then you can add this
EDGE EAS UNIVERSAL TURBO TIMER
Then you will need to get the SCT can get both here.
SCT X3 Custom Innovative Diesel Tuning/ Edge CTS combo
pop
Old Mar 28, 2012 | 06:53 PM
satcom40's Avatar
satcom40
My remote start has a shutdown timer, you can set it for 1 to 4 min for cool down of the turbo, or you go with the Pre-Post lube pump that runs for 5 min and it pumps oil to the enigne.
Old Mar 28, 2012 | 07:29 PM
Regulator1988
all of this sounds like $$
Old Mar 29, 2012 | 05:33 AM
05 f250 6 inch lift's Avatar
05 f250 6 inch lift
what kinda remote start do u have ??
Old Mar 29, 2012 | 09:09 AM
satcom40's Avatar
satcom40
I can't find the manual at this time but I 'm looking for it. I think the name was Viper.
I got went I got the truck in 04.
Old Mar 29, 2012 | 09:16 AM
Regulator1988
Does it let the glow plugs warm up first
Old Mar 29, 2012 | 02:42 PM
satcom40's Avatar
satcom40
It has a 30 sec delay before start, glow plug run about 20 sec
Old Mar 29, 2012 | 02:46 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
Glow plugs run lots longer than 30 sec. Just because the light goes out doen't mean the glows stopped.
Old Mar 29, 2012 | 02:48 PM
Regulator1988
I think he ment it just waited that long for them to warm up
Old Mar 29, 2012 | 02:49 PM
satcom40's Avatar
satcom40
Yes you are correct, but you can start it after the 20 sec.
Old Mar 29, 2012 | 03:46 PM
Regulator1988
That's cool Im going to look into getting one
timmyboy76
19
Aug 9, 2012 09:30 PM
Smokiesman
Jul 5, 2012 08:31 PM
9.ford.5
Canadian National Chapter
Dec 12, 2008 09:57 PM
trucklady
Car/truck Buying Advice
Sep 23, 2004 12:11 AM
