1978 - 1996 Big Bronco
Arctic's 85 Bronco Thread. Ya We Need Help
  #241
Old 11-10-2013, 01:42 PM
arctic y block's Avatar
arctic y block
arctic y block is offline
Hey guys I have decided to bite the bullet and get a reman long block.
351 W HO for the 85 Bronco. I have had good luck with Jasper back in the day
but have no idea where to get one in the Seattle area anymore.
So that is the question for now. What does Napa use now?
What outlet in the Seattle area has a reman long block, preferably a Jasper?
Does Jasper have a site? Guess I can Google that myself when I have a
bit more time.
The sites I have checked so for want around $1500.00 for the HO. I can live with that. Shipping up to me on the barge will prolly be $200.00 or so.
Any help at all is appreciated.
  #242
Old 11-10-2013, 01:47 PM
Encho's Avatar
Encho
Encho is offline
The Southernmost Mod
And what if you send them your core? it should make the price go lower some more.
  #243
Old 11-10-2013, 01:55 PM
arctic y block
On that site I think the price was with sending them my LB. That's not a problem.
I wonder if I am to pay return shipping? I can't spend much if any over 2K getting
it here.
My helper and I can do the swap and save the labor cost. He want's my 22 foot boat
and trailer. Has been helping for a while on other stuff so this would close that deal out.
I have got to take my boy hunting. I will check back in this evening.
Thanks
Rich
  #244
Old 11-10-2013, 02:50 PM
gatorfor88's Avatar
gatorfor88
gatorfor88 is offline
  #245
Old 11-10-2013, 10:02 PM
arctic y block
Thanks Allen that is great. I have some help in a tread I started in the 351W
forum also. When we figure out just what it is I need and want I will give them a call.
I used many Jaspers back in the day. Only had trouble with one 300 I6 that had to thick a casting in the #1 cylinder. The water pump impeller ground on it. Was a hell
of a noise and caused it to eat the pump and over heat. Jasper sent me another
no questions asked and asked me to keep the bad one as they didn't want to
pay shipping. I found that Ford had a shim for the pump as this was a problem
on some early blocks. That free I6 may still be running today.
  #246
Old 01-15-2014, 03:36 PM
fordtrck302's Avatar
fordtrck302
fordtrck302 is offline
I just spent the past hour or so reading through this very extensive thread and many posts will help with some problems on my 84 Bronco. How are things going with your starter problems? Hows the the 351w coming along? I only read one time about your fuel mileage increase after putting on the manual locking hubs, are you still seeing the increased MPG's and would you contribute your increase directly to the manual hubs? Again it's been a great read.
  #247
Old 01-15-2014, 03:52 PM
arctic y block
Yes the manual Warren Premium Hubs gave me about 1.5 MPG increase for sure.
As for the starter I simply put a pry bar (long screwdriver) on the back end frame
and twisted the starter out on the bottom and in on top, than tighten it down. It
has worked as it should with no problems now for a couple of months.
Apparently the indexing plate or spacer between the block and tranny was worn
enough to let the starter lay to far out on the ring gear. When I change to a
manual trans I will replace the plate. But for now it's been working just great. Before if I had to crank on it because I had ran out of fuel or tried to start it hot
and had it kick back it would instantly eat the starter drive. Now it works like factory.
  #248
Old 02-11-2015, 04:58 PM
arctic y block
So okay I had to get a tow from an S10 the day before
yesterday. Sad but true. The Battery went bad and in the
proses of diagnosing that the low volts got the starter to
slip a little. A few months ago I drilled out the upper starter
bolt hole and again pried the starter hard over on top and
closer to the ring gear. It has been working great. Until the
battery took a dump. When the storm passes I will drill out
my spare starter and see if she will go again. As the one in
here was just too worn to catch any at all. If this don't work
than I am in need of replacing the ring gear again. Not fun in
the back yard in winter in Alaska. None of the local shops have
time or any interest in doing it. But I want a 5 speed in the worst
way. I could have bump started it the other day If I had a manual
and not have lost any face. So what to do. Is the Block/indexing
plate the cause of eating starter drives and ring gears? Will it go away
if I again replace them? And where do I find a donor 1/2 ton 5 speed
in the mid 80's to part out for the trans swap? There just isn't one on
this rock to be had. So I have to find one in a salvage yard in the
Seattle area. And hope they will send everything I need.
So here is the big question we are waiting for. Is there any among you
in that area willing to help?
  #249
Old 02-11-2015, 05:47 PM
ctubutis's Avatar
ctubutis
ctubutis is offline
Post this in 80-86, and also maybe in the Washington chapter.
  #250
Old 02-11-2015, 07:48 PM
im2tall33's Avatar
im2tall33
im2tall33 is offline
Why the Washington chapter? Ain't he from Alaska?
  #251
Old 02-11-2015, 07:59 PM
arctic y block
Micah? The closest wreaking yard to me is Seattle. Nothing up
here at all. So Washington is like the south half of Alaska. It has to
come through Seattle to get here. What ever it is.
  #252
Old 02-11-2015, 08:01 PM
arctic y block
Okay, I will try and figure out how to do that in the morning.
Is My nap time about now. Thanks
  #253
Old 02-11-2015, 08:16 PM
ctubutis's Avatar
ctubutis
ctubutis is offline
  #254
Old 02-12-2015, 01:28 PM
arctic y block
Thanks Chris I posted them as you suggested. Anyway I think your name is
Chris? Sounds better than the Mod in the Bra.
  #255
Old 02-12-2015, 09:41 PM
ctubutis's Avatar
ctubutis
ctubutis is offline
Yeah, it's Chris.
It's a shame you're not getting much of a response.
Quick Reply: Arctic's 85 Bronco Thread. Ya We Need Help
