1995 F150 351W Build Thread
#106
After alot of cleaning products and the help of bottle and tooth brushes the intakes are pretty clean. I'm going to strip and repaint the stock upper soon.
I really just want to see how good it turns out. I also may have to use them at first, it depends if I can get that Eddy intake or if I have to wait.
#108
You mentioned this truck was OBD-II yes? For OBD-II Ford didn't put an air pump or any of the accompanying hardware on these engines. No air bypass valves, crossover tube, or air pump. They used a more advanced EGR system and ran cleaner I suppose such that they didn't need the thermactor system.
#109
I'm not sure about that. My friends 96 F150 5.0 is OBDII. It has a smog pump and AIR injection.
#113
I found another oddity with this 96 F250. The 5.8 doesn't have a complete ID number on the block. Also where the date code would be is blank.
Based on what I gathered these numbers are roller 351W blocks.
F4TE-6015-AA-12 for 93/94
F5TE-6015-AA-12 for 95
F6TE-6015-AA-12 for 96
This block is missing the 2nd and 3rd characters. Here is its number. What the heck does this mean? Is it a replacement motor or the last production run or something?
F___E-6015-AA-12
F___E-6015-AA-12
#114
#115
I'm subscribing, because im looking at doing a very similar build on my 351W as soon as i get the other stuff in the garage running again...
If you don't want it, i'll take that pulley off your hands ... PM me if u want to sell it...
#116
Sorry, I'm keeping the pulley. I hope this thread helps with your project.
#118
My 96 F150 5.8 never had an air pump. The exhaust manifolds don't have the fittings for the injection. The heads had pipe plugs in place of the crossover tube. No tab/ted solenoids either. HD tow package: so thick radiator, oil cooler, and the larger trans cooler.
My donor motor was out of a 90' F250 with the dual thermactor system, what a mess. Reused the 96' intake and exhaust. Yeah the 96' heads are roller, but the 90' runs great and I still get the same mileage on the highway.
You will love the 5.8 over the 5.0. I have driven each extensively and am very glad my truck is a 5.8.
#119
#120
Subscribed! I'm gearing up to rebuild my 1990 351W and have the same general vision. Still looking for my GT40 heads, but will probably follow your lead on the cam and headers (at least to start). Not sure where I'll go with the intake longer-term, but figure that's the easiest thing to swap out at a later date... The typhoon does have me thinking though!
I'd love to see some more pics as your working it all out... My hat is off to you my man- seems like you're setting a trend with 351w owners!
