400m carb curb idle?
Old 03-26-2012, 07:26 PM
joel79ford's Avatar
joel79ford
joel79ford is offline
Today I am going to adjust the timing of my engine
but before I do I want to know how I adjust the idle speed
Where do I turn the screw clockwise or counter clockwise?
Oh and what's the idle recommendations? Right now its at about 800 rpm
Old 03-26-2012, 07:30 PM
devino246's Avatar
devino246
devino246 is offline
clockwise raises it, counter-clockwise lowers. Should probably be 550 +/-50
Old 03-26-2012, 08:01 PM
old ford user's Avatar
old ford user
old ford user is offline
My 77 Ford F150 4x4 has a 400 with 2 barrel 2150 carb and C6 Auto the Ford valve sticker is still on it. It specifies 650 RPM curb idle with the truck in neutral with the idle solenoid wire disconected. I used the screw on the drivers side to adjust idle with a tach hooked up at the coil after the engine was warmed up and the temp guage up at the middle
Old 03-26-2012, 11:18 PM
joel79ford's Avatar
joel79ford
what do you mean by "550 +/-50" ?
sorry, im new to this stuff
Old 03-27-2012, 01:47 AM
2hole's Avatar
2hole
2hole is offline
lol 550rpm idle speed; plus or minus 50 rpm
Old 03-27-2012, 10:13 AM
devino246's Avatar
devino246
What he said^. There's usualy a range rather than an exact speed. Some engines idle better at 600, others do fine at 500.
JimG1098
11-11-2012 02:01 PM
crashtke
10-01-2010 09:53 AM
61 uni
03-04-2010 06:49 PM
hotbbb
02-07-2004 08:59 PM
slim_falcon
05-26-2003 10:38 PM
Quick Reply: 400m carb curb idle?
