little O/T 01 7.3 lacking power
Old 06-29-2013, 01:13 PM
tshrager's Avatar
tshrager
tshrager is offline
Sounds like my brothers SD. It's got so many oil leaks and issues, that I'm trying to talk him into a motor swap. At least he bought his that way. I told him he never should have got it, but it was cheap and has a clean body.
Sounds like you'll have him right in no time.
Old 06-29-2013, 01:22 PM
427 fordman's Avatar
427 fordman
427 fordman is online now
I hope so Todd. I think this guy had this since it was new, so I know it hasn't been treated very well at all. This body is quite straight actually, not even a crack in the dually fenders, but I don't think the inside has ever been cleaned. Drivers window doesn't work either. I can hear the motor, but no movement. Anyone has an idea for that I'm all ears there too.
Cheap with a clean body can go a long ways, body work/paint job is real expensive!
Old 06-29-2013, 10:19 PM
oldbird1965's Avatar
oldbird1965
oldbird1965 is offline
Got your hands full, huh Darin? The window could be the plactic rollers are off track or the motor gear is not engaged.
Old 06-29-2013, 10:31 PM
fordman67's Avatar
fordman67
fordman67 is offline
The 3 little pucks in the gear box have desentgrated cheap fix in the "help" section
Old 06-29-2013, 10:40 PM
fordman67's Avatar
fordman67
I wonder about the up pipes also...
the clutch...we would prob replace the hyd IF the fork was not bent or broke.total junk hydros used to replace the systems all the time.
Old 06-30-2013, 05:48 AM
427 fordman
Ya Glenn, this thing has the dirtiest engine compartment I've ever worked on. Besides this guy is terrible with maintenence, he is a dirt worker, so you could imagine what the inside of the truck and under the hood look like.
Aaron, the uppipes don't seem to be leaking. I don't see any soot or evidence of any kind. The clutch I'm not going to mess with now. I'm sure its original with 205k on it, so its probably just time for a new one. In fact, I'm not gonna mess with the window right now either.
I decided I better get it back together and make sure its running ok before I stick any more time, money, and effort into it. I'll place an order with Clay and after I get it back together, then maybe I'll mess with the window and other things if its running good.
Old 07-01-2013, 08:08 AM
DIYMechanic's Avatar
DIYMechanic
DIYMechanic is offline
Wow, sounds like you have your work cut out for you.
Correct me if I am wrong, but if the clutch is releasing down at the bottom of the pedal stroke, wouldn't that tend to indicate that the clutch is tight and not loose (needing to be replaced)? Maybe I misunderstood you. I always thought that if the clutch released soon after you started to let the pedal out that meant that there was quite a bit of life left on the clutch. Maybe I'm thinking wrong?
Old 07-01-2013, 12:50 PM
Hussler's Avatar
Hussler
Hussler is offline
Originally Posted by 427 fordman
1670 I need a little advice on. P1670 EF Feedback Signal Not Detected That's what it is, but I'm unsure what that means.
Thanks guys.
When the PCM sends commands to the IDM the IDM responds back to the PCM a mirror image of that command. The IDM uses the EF (electronic feedback) line to do this. The IDM also uses the EF line to report trouble codes to the PCM. If this line goes bad then the truck will run OK but should set a code, which it did.
Could be a problem in the IDM or the connector from the IDM to the PCM.
Old 07-01-2013, 05:05 PM
427 fordman
Nate, I really don't know either, but I thought it meant it was worn. I'm no clutch man.
Thanks for that information Jim. I'll get it back together and see where I'm at with it. I'll try cleaning some connections, that could very well be the problem as dirty as everything else is.. I guess I could try my spare idm also.
Ordered some stuff through riffraff, sure is nice to be able to get all I need in one place. I got a bunch of things, boots, clamps, plenum inserts, orings, icp sensor and pigtail, filters, etc.. I like one stop shopping. I have oil and a filter, so I don't even need to make a stop at the parts store.
Old 07-06-2013, 11:44 AM
427 fordman
I haven't gotten back on this yet, but I'm heading out of town for the weekend and just thought I'd show you a picture of the air cleaner. This is after a lot of the chunks have fallen off. Kinda gives you an idea of what the rest looks like.. The boots, spyder, everything looked like this.
Old 07-06-2013, 11:58 AM
fordman67's Avatar
fordman67
Wow...how to not maintain a psd...
87 F-150 I6
6.7L Power Stroke Diesel
11-10-2016 08:48 PM
idt-572
09-20-2012 02:58 PM
preppypyro
10-27-2009 10:56 AM
big ol' blue
28
07-11-2009 02:02 AM
blong2107
25
04-21-2008 07:44 PM
Quick Reply: little O/T 01 7.3 lacking power
