Should I replace a water pump?
Old Mar 30, 2012 | 08:20 PM
Boss9F100's Avatar
Boss9F100
Originally Posted by Schuyles
My buddy said they used a propane torch and that the broken bolts came out pretty easy...
here is the new pump back in the truck.
If there is any sign of the frost plugs leaking I would get them at the same time.
Very little cost now but if one lets go it could be . . . I prefer the brass ones
And yes heat is your friend when bolts are tough to get out.
Old Mar 30, 2012 | 08:32 PM
Schuyles's Avatar
Schuyles
I have to admit I don't know where the freeze plugs are or how to inspect them or where to get replacements.
Any help would be appreciated!
Old Mar 31, 2012 | 02:01 AM
Boss9F100's Avatar
Boss9F100
There are 5 on side of block passenger side, one on back of head and one on back of block.
I will get a pic for you.
Old Mar 31, 2012 | 02:06 AM
Boss9F100's Avatar
Boss9F100
List: Freeze Plug - Block Kit - 1965 Ford F-100 Pickup | O'Reilly Auto Parts
Above is kit for approx 10.00 for all you need.
Just take a large screwdriver and hammer and hit on probably top edge as will have less rust than bottom side. The plug will turn in hole. Then just take channel locks or a plier - Vise grip and pull them out. Using a proper sized socket to knock them back in. I prefer the brass kits as listed. They make a expansion plug/freeze plug installer but the socket/extension works well too. I normally put some type sealer on plug before installation.
Old Mar 31, 2012 | 02:10 AM
Boss9F100's Avatar
Boss9F100
here is a decent pic of my 6 showing the locations. Note that many were leaking! If you were local I would just install them for you.
Old Mar 31, 2012 | 08:08 AM
Schuyles's Avatar
Schuyles
Thanks for taking the time to explain this and posting the pic!
Snowseeker
15
May 13, 2014 08:07 AM
mypigpen
Oct 16, 2010 03:45 AM
The79Beast
Jul 24, 2009 11:35 PM
bigfry
Apr 22, 2005 03:38 AM
ddbuggins
Dec 15, 2004 12:28 PM
