Header install
Old Mar 25, 2012 | 07:33 PM
fairfield86f150's Avatar
fairfield86f150
Header install
So i just got my headers installed. It's on a 351w
Now i don't have any exhaust installed other then the headers, and i wanted to tune the truck some more.
After i kicked off the high idle and the choke was off, the tach was reading 1100 in park. Now i would put it in drive ( and before the header install it would idle in drive at 600) now it just dies as if it's too low of an idle.
At a loss here.
Old Mar 25, 2012 | 08:01 PM
82f100460's Avatar
82f100460
did your old exhaust have an O2 sensor that is no longer there...but the computer is looking for it's signal maybe?
Old Mar 25, 2012 | 08:11 PM
Gary Lewis's Avatar
Gary Lewis
What else has been changed? Is it injected? If not, computer? Need to know more about the situation.
Old Mar 25, 2012 | 08:19 PM
82f100460's Avatar
82f100460
Well you mention high idle and choke so I'm assuming it has a carb.
Almost sounds like it's getting hung up on the high idle still. did you bother the choke at all? How about the electrical feed to it? That comes up on the passenger side by the headers right?
Old Mar 25, 2012 | 08:36 PM
fairfield86f150
It's not injected, it has a 4180 carb on it. I had just fixed the choke and fast idle cam before doing this install.
I checked to see if fast idle cam kicked off and it did, and choke opened all the way.
It was idling at 1500 at this point in park, so i unscrewed the idle screw abit to get down to 1100.
Then when i put it into gear it sputters and dies. This of course is all after i let the engine warm up
Old Mar 25, 2012 | 08:50 PM
Gary Lewis's Avatar
Gary Lewis
It should be idling more like 750 in neutral or Park and drop to 600+ in gear. Dropping it in gear at 1100 RPM is rough on things.
It sounds like your idle mix is way off. I don't know why it would be with just installing headers, so I'm thinking it is something else, like vacuum lines, plural, off. Or the carb isn't bolted down. Work to get your idle down to ~750 and very smooth, using a vacuum gauge to tune the idle mix. You should have something like 19 or 20" of vacuum at that RPM. I'll bet when you get it to idle at that speed with that vacuum it'll drop in gear and settle down to ~600.
Old Mar 25, 2012 | 08:54 PM
82f100460's Avatar
82f100460
I'm far from a carb expert but was told by a friend once that when he put headers on his Mustang it reduced the back pressure so much that he ended up having to change the power valve....It apparently also changed manifold vacuum.
I'm not sure how accurate or possible this would be...but if it is, then it would also be reasonable that it would change the idle mixture.
Sounds like a good question for Bill
Old Mar 25, 2012 | 09:32 PM
ctubutis's Avatar
ctubutis
I wouldn't mess with it 'til I put the full exhaust system on.
Old Mar 25, 2012 | 09:39 PM
fairfield86f150
Also, when removing the drivers side exhauset manifold, i removed this as well (item in picture) it was hooked up to a vacuum tree on the back of the intake manifold, when i removed it i capped of the vacuum line on the intake.
Old Mar 25, 2012 | 10:28 PM
Gary Lewis's Avatar
Gary Lewis
That's the vacuum-operated heat riser. When shut it forces exhaust through the passage in the bottom of the intake manifold to the other side of the engine. That raises the temp of the incoming air/fuel mix and helps the engine run in cold weather. Vacuum then was applied to it when the engine got warm to allow exhaust to come out on the driver's side.
Old Mar 25, 2012 | 11:24 PM
fairfield86f150
ok so i shouldn't really need it, i can run without it right
Old Mar 26, 2012 | 08:00 AM
Gary Lewis's Avatar
Gary Lewis
You may notice that the engine takes longer to be truly warmed up on a cold day, but you can get by without it. I don't think you have any choice with headers.
Old Apr 1, 2012 | 01:36 PM
fairfield86f150
Ok so I fixed my problem. I retarded my timing slightly to get the idle smoother.
Then I turned the idle mixture screws back one turn each ( this gave me the highest rpm, and smoothest idle)
Then I set my curb idle.
Truck starts and runs like a top now
Old Apr 1, 2012 | 01:44 PM
82f100460's Avatar
82f100460
Excellent!!! Thanks for the update and very glad you got it figured out
Becauseican1
Jul 13, 2013 02:06 PM
79F250inline
Dec 8, 2010 04:34 PM
masseysbronco
Oct 4, 2010 06:45 PM
93candycane
22
Aug 29, 2004 06:10 PM
Truckboy
Dec 26, 2003 09:39 AM
