HPOP pressure
Old Mar 25, 2012 | 07:37 AM
RRranch's Avatar
RRranch
HPOP pressure
What was the maximum pressure on the high pressure oil for a 94.5? I had my manual on a computer that just died and can't look it up. On a warm day now floored at 3000 rpm I'm seeing about 2800. That's with the chip in stock mode. I know it fudges the readings in any other setting. I swapped my sensor too just in case it was bad. No change. My o rings are only two years old so I think I need to get off my butt and pull my engine. I have a new front cover and pump sitting here but haven't had time to do it yet with all the miles we've been driving.
Old Mar 25, 2012 | 08:18 AM
427 fordman's Avatar
427 fordman
I thought that number was about right? You don't cel like a 1211 with the chip in any mode do you?
Old Mar 25, 2012 | 09:30 AM
fordpride's Avatar
fordpride
If your holding 2800psi. I'd say you have a strong pump.
Whats the IPR DC%?
Old Mar 25, 2012 | 09:37 AM
Talyn's Avatar
Talyn
2800 is good.
Old Mar 25, 2012 | 10:21 AM
oldbird1965's Avatar
oldbird1965
2800 in stock position is right on. What O rings are you referring to? What pump do you have?
dannyboy950
Jan 21, 2015 05:03 PM
bigbubba87
Apr 1, 2014 12:14 PM
7636074460
Apr 30, 2013 06:31 AM
bloomy63
Nov 3, 2006 10:08 PM
bikerwolfie
May 16, 2002 05:27 PM
