Wrong sender?
Old Mar 24, 2012 | 09:23 PM
Dr_Gonzo's Avatar
Dr_Gonzo
Wrong sender?
I've been trying to get my fuel gauge issues figured out. Guy I bought it from said it would run out at a quarter tank. 76 F250 with in cab tank. I pulled the sender today, hooked it up and moved it manually. Gauge responded correctly with me moving the float. There's not much gas in the tank, yet it reads a half when the float hits the fuel. So, did someone install the wrong sender? Maybe bent the arm? I guess the only way to calibrate it would be to run it dry then bend the arm to set it to empty.
What do you guys suggest?
Old Mar 25, 2012 | 05:17 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Sounds like a great way to save having to buy another sending unit. Instead of running dry, just siphon the gas out and then bend the arm to indicate empty.
Or adjust it to indicate E at a 1/8 to prevent you from running out?
jeremywatco
Jul 5, 2019 06:02 AM
petermck
Nov 21, 2016 06:33 PM
NashvegasMatt
Sep 13, 2016 07:50 AM
triumph1200
1947 and Older Ford Trucks
16
Aug 25, 2016 09:42 AM
dbellis
Apr 9, 2007 12:21 PM
