1966 F150 build
#61
#62
#64
Another good day for progress.
I got the bed off using my little engine hoist. It wasn't too bad, but I'm looking forward to using the I-beam next week.
All of the demo work on both frames is done. (Woo Hoo) Now I can start building the new chassis.
Here's all of the crossmembers out. I've ground out about 70 rivets between the two frames.
YES! So far, my math is working out. I have the rear section clamped in. The wheelbase is spot on. The frame rail sections fit perfectly like I planned. and it looks like I can have the rolling chassis I wanted tomorrow.
Here's a shot of the overlap where the sections fit together.
Here's the '66 after the frame was cut off. ...it's a little shorter.
#65
#66
The wheelbase was exactly 2 feet longer than the Bronco. I was just going to stretch the bronco frame, but with the frame rails kicked up 4" in the back, I would have to do some serious fab on the body mounts. This way, the frame is stronger and the bed bolts right down with only a few holes drilled.
#67
#71
#72
Well, I didn't get as far as I wanted, but I did get something done. It's almost a rolling chassis. I still have to mount the shackle mounts and finish weld everything. It's getting closer.
The shock isn't permanent. I need a longer shock. I just wanted to check the angle. (it's looks good.)
Here's about half of the rivets ground out. The other half was shot across the shop or yard.
#73
Another disappointing day. Every time I try to work on this thing, something always happens to slow me down. Today, it was my MIG gas. It was labeled 75%/25%, but that's not what was in the tank. It was a spattering mess. I swapped out the tank where I got it and now my welder works like new again.
I got the chassis finalized. Everything is welded and set where it belongs.
Here's a shot of the splice. Each side is plug welded in 9 spots along with a 10" overlap and 2 FEET of weld on each side. It ain't going NOWHERE!
#74
I started putting stuff back in the chassis. The gas tank is in. I may need a body lift or some creative welding to clear the crossmembers under the bed.
I cleaned and painted the Bronco shocks and put them back on.
I got the E-brake cable bracket back on too.
This is a super budget job. I'm to the point where he has to pony up some parts. I'll give him a list tomorrow. Here's where I left it today....
#75
