One wire alternator
Old Mar 24, 2012 | 05:27 PM
birdhaus's Avatar
birdhaus
One wire alternator
I have a possible bargain basement deal on a new Powermaster alternator... for my '65 352, (really a barter deal, but a good one.)
has anyone had any experience with a Powermaster 8-37141 or similar?
Right now I'm studying the Powermaster Website.
Is upgrading to a one wire system as easy as the on-line instructions say?
Quote, "
The only thing required to electronically hookup a one wire alternator is to run a charge wire from the battery terminal on the alternator to the positive terminal on the battery (or any positive battery source)"
That means the whole shooting match on one output of the alternator?
Old Mar 24, 2012 | 07:50 PM
63' f100's Avatar
63' f100
Yep. It really is that easy. I attached it to the positive wire that goes to the generator, but it is the same thing. The negative comes from the engine already being grounded, so you don't need a negative wire. This is assuming it has an internal regulator, which most do.
Old Mar 24, 2012 | 08:17 PM
pburress's Avatar
pburress
It gets a little more complicated if you want your dash warning light to work...
Old Mar 24, 2012 | 08:33 PM
birdhaus's Avatar
birdhaus
Thumbs up Thanks
Excellent news. Thanks for the speedy reply gents. I guess I'll do the deeds..
Reading the FAQ about that model tells me it has an internal voltage regulator and requires the engine to turn at over 1500 rpm before it starts charging,
and stays on until it shuts down.
Fancy stuff.
Old Mar 24, 2012 | 10:40 PM
63' f100's Avatar
63' f100
I'm all for keeping trucks original, but generators SUCK. I'm happy with my alternator conversion and I'm sure you will be too.
Old Mar 26, 2012 | 10:27 AM
daveengelson's Avatar
daveengelson
Came across article in the 'spec's/article' forum, I have not had opportunity to read as yet but you may find some of the info helpful?
One Wire Delco alternator Installation In A Classic Ford Truck .: Articles
Old Mar 26, 2012 | 05:07 PM
birdhaus's Avatar
birdhaus
Thanks
Good read... Thanks for posting.
Old Mar 26, 2012 | 09:58 PM
dvandervossen's Avatar
dvandervossen
Anyone have an idea what would fit on a 240 or 300?
66f103ontree
Electrical Systems/Wiring
Oct 15, 2018 07:29 AM
elkarcher1716
48
Apr 29, 2014 09:03 AM
augustjames
Apr 7, 2014 06:46 PM
joshofalltrades
Nov 30, 2012 02:58 PM
tamwill
Jun 6, 2001 01:32 AM
