Old diesel blocks VS new diesel blocks with multiple injection events.
#31
#32
And again we are not comparing Detroit diesels mounted in semitruck making 100,000+ miles year after year, but we are comparing light duty engines used in pickups, SUV and vans.
Are you trying to say that a superduty diesel engine is in the same category as a small diesel in an SUV or car? It's JUST like comparing a detroit diesel to smaller, the engine is designed to operate at a certain load in mind.
You don't need much HP for pulling heavy trailer at low speed. My 21 HP tractor will pull 20,000lb easy. It is the speed that makes the engine working at the top of the output.
No, but at highway speed, a trailer can take a lot of power to get and keep moving, thus heavy duty engines.
So bottom line those 400lb European diesels run at the top of their output for million miles easy, when even the best PowerStrokes are usually rated for 400,000 miles, excluding single examples that run much higher.
Are you saying you think that the european diesels will run at WOT for a million miles?
#33
From brand loyal toyota freaks, the tundra 4x4 gets 20-25 mpg. From anyone not trying to defend them, I hear 14-18 mpg highway, depending on the usual variables.
And Kajtek1,
The problem with comparing small super high performance engines to larger heavy duty ones, is that they are just not the same breed, and designed for totally different lives.
No matter what hp engine you have in a car, the average output of the engine, over the lifespan of the car, will be very low.
The diesels in a truck designed for towing, are made for constant moderate to high output.
These are not high end luxury, or racing diesels, they are work trucks.
And Kajtek1,
The reliability and long life might not be big issue for average owner making 10,000 miles annually, but why the 20 years old Sprinter engine can make 20-25 mpg pushing big box, while the best new Superdutys can't touch 20 in pickup?
#34
SD's can make 20 mpg.
The sprinter is not 4x4, doesnt have barely any towing capacity, anyone i talked to said they wouldn't tow anything with it.
The sprinter is basically a diesel minivan with heavy suspension.
Also, remember fuel here is a lot crappier than over there, theres a lot of people who have been disappointed with their sprinter vans in NA.
I'm confident ford could make a 20-25 mpg diesel van, but as it turns out it seems that people would rather have a giant truck with lots of room and towing ability as well as offroad ability.
#35
Before you go any farther with this nonsense, do some homework. Compare the % of original price used Sprinters sell for and used Superdutys sell for.
#36
You're saying the sprinter gets 20-25 mpg.....
It weighs less....
Less almost non existent towing capacity...
I don't see what the point is, I'm not surprised at all of the sprinter mileage, the super duty is a far more capable vehicle. And for the weight ratings, towing ability, and power, I think the mileage is very respectable.
#37
#38
Diesel engines are cold-blooded, so the main problem with them is running too cold, while it is only last 20 years when they become so powerful that you don't have to drive them at WOT all the time.
I used to drive 44HP VW diesel pickup for few years. It had only 2 options for power -WOT or idle. There was no use of keeping the gas pedal between. Yet even the engine that originated as converted gasoline engine last for long time. Check what kind of value those model that still lasted can gain today?
Looks to me that owners appreciate 40 mpg from the truck more today than 30 years ago. When you compare the fuel prices, it is quite understand. 5 years ago talking about Smarts was bringing big laugh on US forums. Today I see lot of Fiat 500 on our roads. All it took was tripling the fuel prices in this period.
#39
No it does not. Its a PFI engine...but so is the 3.7, 5.0, and 6.2. Direct injection offers 3-6% at best better fuel economy without taking into account the power it takes to pressurize the high pressure fuel pumps. Additionally, PFI does not have the intake valve coking that you get from the PCV / EGR in a gasoline engine. Ford's 3.5 shows some awful fouling of the intake valve seen here (BGFuelTest.com The Fast and The Fuel Test). More research show that Toyota's direct injection offered in the Lexus line is by far the most advanced because it is a hybrid system of PFI and Direct. I would be very interested to see how the ecoboost engines will perform when these valves get more and more dirty over time.
Toyota has had this for years as well as Honda. The 5.7 is a dual VVTi engine on both the intake and exhaust cams. Ford is late to the game and the 6.2 is old tech. The 5.0 is a nice engine, but you need DOHC in order to have independent intake and exhaust timing.
You are right there....but how many speeds were in the F-150 in 07.....seems like plenty of people said that was enough. As for me, I think the Corolla sucks as a small car. I would buy a Hyundai Elantra.
As a previous owner of a Tundra 5.7 Crewmax....I will tell you it does not. I will do 18-19 empty. It will also outpull the Ford offerings and will provide better fuel economy while pulling a loaded trailer than the Ecoboost. It is well known that the Ecoboost provides poor at best fuel economy while being used as a truck (not grocery truck). Even Pickuptrucks.com showed the extra soot generation of the ecoboost which shows that the engineers are running this truck with a lower AFR in order to manage cylinder temperatures and provide enough enthalpy (heat flux) for boost production. Mileage comparing the 6.2 and the Toyota 5.7 shows the 5.7 is by far the better engine for TOWING fuel economy. A quick gander over in the F-150 forum shows many owners unhappy with their fuel economy of the ecoboost. I WAS on Ford's bandwagon, but now when I sit and think about the data in front of my face...a 5.0 would probably be a better engine in that truck for consistent fuel economy.
Plenty of Isuzu and Hino trucks running around here in Ohio that pull 33k no problem. I don't see the argument here. Yes, Toyota doesn't make a heavy duty....but honestly that would be a poor decision on their part. They should make a diesel Tacoma and then they'd own the small truck segment forever.
6k I think.
Now that I'm done addressing those questions, lest talk about mean effective pressure. I honestly do not know what the iMPEP (indicated mean effective pressure) Ford has in the cylinder while going through the combustion event. I can calculate BMEP (Brake Mean Effective Pressure) which is just a measuring stick used to show what pressure if uniformly distributed on the top of the piston from TDC to BDC would produce the rated power of the engine.
Since we make 800 ft lbs of torque vs 650 in the 6.4, the BMEP of the 6.7 would be higher.
BMEP (psi) = 150.8 x TORQUE (lb-ft) / DISPLACEMENT (ci)
That does nothing to say that the indicated peak IMEP is higher due to the pilot injection. My guess is peak pressures are higher in the 6.7 due to increased combustion efficiency and volumetric efficiency. Additionally the pilot injection allows for a more complete burn of the fuel since it has the ability to mix better. Lastly, Piezo injectors allow for much smaller fuel droplet sizes which increase totals surface area of the fuel allowing for quicker ignition timing resulting in less carbon emissions (soot).
I can get into this debate all day, but I don't have the combustion analyzer data that Ford's engineers have to know definitively whether pilot injection increases or decreases cylinder pressures. Since we are making more power with the 6.7, our pressures are higher, but this could be due to a myriad of things and not just pilot injection.
We do know from Ford's <acronym title="Page Ranking"><acronym title="Page Ranking">PR</acronym></acronym> video that a 6.7 will idle w/o pilot injection (their noise advertisement).
Quiet New Ford 6.7-liter Power Stroke Turbocharged Diesel Engine - YouTube
How 'bout independent variable cam timing?
Exactly how many speeds are in a Corolla transmission again?
Does the Tundra get 21 MPGs in 4x4 trim?
Which foreign diesel heavy duty pickup can operate at 33,000 lbs GVWR?
]How much can a Ridgeline tow, BTW?
#40
On a good day, maybe.
It is snappy, but I wouldn't compare it's ability and features to an f150.
Ya those aren't pickup trucks. Are you talking the LCF models? Those have ~200 hp and are slow.
We do know from Ford's <acronym title="Page Ranking"><acronym title="Page Ranking"><acronym title="Page Ranking">PR</acronym></acronym></acronym> video that a 6.7 will idle w/o pilot injection (their noise advertisement).
#41
Awesome post though, thanks for the info!
#43
#44
#45
Do you have any idea how many products are MFG'd in china that might be shady in the patent infringement department ? lol
Anyways those motors in those little cabover trucks are not high power units.
A super duty could drag race them with trailers, loaded, and definately win.
