Tips for swapping a 6.0 oil cooler into 7.3 2002 Excursion
I'm the process of doing the swap. For the life of me, I don't see how you can access the screws at the bottom of the oil cooler. Any and all help will be very much appreciated.
There is a box tube beam right behind the black plastic apron below the bumper that has 3 bolts on each end. Take that off and there should be enough room to get to the trans cooler screws. I didn't have to remove the bumper when I installed ours. Removing the AC condenser upper brackets will allow tilting the condenser to gain some room from the top.
Drop the crash bar off the bottom of the frame up front (under the bumper). Once you do that, the cooler is super easy to get in and out. That is what Babich was telling you up above in post #4.
