Quick help please, turbo rebuild
Old Mar 23, 2012 | 06:35 PM
DemonRace6's Avatar
DemonRace6
Hi!
I am in the process of rebuilding my turbo and I do not know where these two parts go that came with the rebuild kit. I do not have any instructions on how to do this, I have just been pulling it apart and replacing all the parts but these parts were not in the turbo when I pulled it apart.
Old Mar 23, 2012 | 06:58 PM
DemonRace6's Avatar
DemonRace6
Hi!
Bump, pleaseee
Old Mar 23, 2012 | 07:24 PM
meierw1's Avatar
meierw1
They are both oil seals. The smaller one goes on the thrust bearing and the other goes on the shaft near the exhaust turbine. Go to the riffraff sight and you can download the instruction for the gtp38 rebuild.
Old Mar 23, 2012 | 08:34 PM
woodnthings's Avatar
woodnthings
Here are the turbo rebuild instructions from Riffraff Diesel.
http://www.riffraffdiesel.com/mm5/RE...bo_Rebuild.pdf
Old Mar 23, 2012 | 09:26 PM
DemonRace6's Avatar
DemonRace6
Hi!
Thanks guys, reps sent to both of you. I put those in the right place now but it is hard to spin the wheel now. Should it feel totally free spinning like it used to with the worn out bearings?
Old Mar 23, 2012 | 09:38 PM
BadDogKuzz's Avatar
BadDogKuzz
When you installed the turbine shaft did you feel the shaft seal lock in the turbine housing? Because there is a small groove that the seal goes in on the turbine housing. I had to clean the groove out (pick tool) on the turbine housing for the seal to seat in. Or I have heard of guys tapping the end of the shaft with a wood block or wood hammer handle to get it to fully seat.
Then install bearing, spacer and bearing (pre oiled) and the shaft should spin freely if so you are good.
Old Mar 24, 2012 | 12:21 AM
Bonanza35's Avatar
Bonanza35
What Ed said. Pull it back apart and inspect the whole thing. When it goes together it should spin very easy.
Chet
Old Mar 24, 2012 | 03:51 AM
twags6's Avatar
twags6
Make sure you clean everything out real well. I had to pull it back apart 3 times cause I missed small pieces of burnt oil other oozing goo that got past the seals. Definitely pre-oil it too and make sure nothing is rubbing. I got dirt between the compressor housing back plate and center cartridge at one point and it was enough to make the fins on the intake side rub the compressor housing! Oh, I used a little 1lb baby sized dead blow hammer to seat everything. Worked great.
Old Mar 24, 2012 | 10:20 AM
DemonRace6's Avatar
DemonRace6
Hi!
Thank you very much guys. I got it all back together thanks to you. Before I put it back in the truck though I took a quick video of how well it spins now. Still stops pretty quick but MUCH better than before. Is this good?
Old Mar 24, 2012 | 10:52 AM
DemonRace6's Avatar
DemonRace6
Hi!
Bump, anyone know if its good to go back in the truck?
Old Mar 24, 2012 | 12:09 PM
woodnthings
That looks like it is fine. With a little oil on the bushings and the shaft, I would expect it to do that.
Old Mar 24, 2012 | 12:17 PM
BadDogKuzz's Avatar
BadDogKuzz
I concur with Ken !!! You are good to go !!
Old Mar 24, 2012 | 01:45 PM
meierw1's Avatar
meierw1
When you put the compressor housing back on check to see it hit the housing. Other than that it looks like its good to go, make sure you don't exceed 2000rpm for the first 50 miles or so give the new bearing some time to break in.
Old Mar 24, 2012 | 02:33 PM
Bonanza35's Avatar
Bonanza35
I never heard of the 2000 rpm deal but mine spin way earier then that and just kept spining till slow down. But I guess as you run it it mit free up as long as the shaft isn't bent.
Chet
Old Mar 24, 2012 | 03:46 PM
DemonRace6's Avatar
DemonRace6
Hi!
Mine old one used to spin much easier also. I also just hooked up my boost gauge for the first time to the AIH port on the intake and did the AIH delete. I just finished and started the truck. Everything sounds fine but I do not hear the turbo spooling up or see any boost on the gauge. I have not driven it yet, just started it for about 2 min and put it up to about 1900 rpm. Should I be seeing boost on the gauge at idle or at 1900 rpm? Maybe I should let it warm up more first?
