Factory Engine and Intake Paint
Old Mar 23, 2012 | 04:54 PM
TexasGuy001's Avatar
TexasGuy001
I'm interested in finding out what color gray Ford used on the block, valve covers, and intake on our trucks. Does anyone know what its called or what the best match is?
Old Mar 23, 2012 | 06:43 PM
882tank's Avatar
882tank
I've used the Duplicolor Ceramic New Ford Gray on my 96. It is almost a perfect match. Still holding up beautifully, but I've only put 10K on it since.
Old Mar 25, 2012 | 12:56 AM
TexasGuy001
Do you have a pictures if how it turned out? Did you clearcoat it?
Anyone try anything else?
Old Mar 25, 2012 | 01:16 AM
882tank's Avatar
882tank
I didn't clearcoat it. Just primer and top coat. I'll snap a picture for you tomorrow.
Old Mar 25, 2012 | 01:54 AM
Tsoptich's Avatar
Tsoptich
If you don't mind a flat look, a friend of Mir used BBQ paint on the block holds up to heat and really easy to notice leaks the valve cover I old use the duplicolor ceramic paint for a clean finish.
Old Mar 25, 2012 | 02:26 AM
deljac's Avatar
deljac
thru tractor supply its a lite ford gray is a good match
Old Mar 25, 2012 | 10:35 PM
882tank's Avatar
882tank
As promised Texas, here's a pic of my VC for you.
Old Mar 26, 2012 | 04:11 PM
TexasGuy001
That valve cover looks really nice. Is that the actual name of the paint? Did you use regular or etching primer?
I had not thought of going to tractor supply for paint.
Does anyone know if the 5.0 and 5.8 upper intake were the same color as the valve covers?
I guess the 4.9 intake wasn't painted.
Old Mar 26, 2012 | 04:41 PM
Diesel_Brad's Avatar
Diesel_Brad
The intakes were NOT painted gray like the block and valve covers.
I would NOT use a primer, unless it is HEAT rated primer just like the paint is HEAT rated
Old Mar 26, 2012 | 05:05 PM
882tank's Avatar
882tank
That is the actual name. The primer I used is a heat rated primer also made by Duplicolor. It's meant to be used with their ceramic engine paints.
Old Mar 26, 2012 | 08:01 PM
TexasGuy001
What was used on the intakes?
Old Mar 26, 2012 | 09:49 PM
882tank's Avatar
882tank
If I recall (correct me if I'm wrong anyone), the intakes are Ford Argent Silver. VHT carries it in a high temp paint.
Old Mar 27, 2012 | 02:51 AM
TexasGuy001
I was thinking it might be Argent Silver too. My rear bumper has Argent Silver on the hitch/step area by the license plate. It seems that its a lighter color than the intake, but its hard to tell since the intakes I have both 5.0 and 5.8 are old and kinda discolored.
Old Apr 2, 2012 | 02:16 AM
TexasGuy001
Does anyone know what color the stock intakes were painted? I want to restore the 5.8 one, as I may have to use it for a little while.
Old Apr 2, 2012 | 11:06 AM
peter_x's Avatar
peter_x
My '97 5.8 has the intake (at least the upper) painted the same gray as the valve covers. I don't think the lower was painted because I don't remember scraping any paint off when I cleaned it up to turn it red. I can't remember if either intake is painted on my '88 7.5, although the valve covers were still gray.
