pickup bed #
Old Mar 23, 2012 | 10:03 AM
schoo's Avatar
schoo
pickup bed #
how much does my f250 8' styleside bed weigh? sold it and know have to pick it up, got a cherry picker but think 4 big guys ( i'm small) could get off the frame?
?#2 they use self locking nuts on the bed? they are hard to get off used a sawzall and grinder
Old Mar 23, 2012 | 02:27 PM
bertha66's Avatar
bertha66
4 average size guys can remove a bed, done it myself. Careage bolts with nuts and lock washers, not self locking bolts.
Old Mar 23, 2012 | 02:46 PM
schoo's Avatar
schoo
thanks the nuts on mine got harder the closer i got to the end tried to go back but didnt help looked like lock nuts two more to go not in a rush
Old Mar 23, 2012 | 03:04 PM
63' f100's Avatar
63' f100
How did you remove it yourself? I think i may pull my bed to paint the chassis. I don't really want to have to have people come over because I live out of town and its inconvenient for others to help with that.
Old Mar 23, 2012 | 05:00 PM
schoo's Avatar
schoo
i haven't done it yet but i think that will use cherry pick at one end and a friend & me at other and load on to trailer just swing around
i'm out in the sticks also.
Old Mar 23, 2012 | 06:03 PM
Cal250's Avatar
Cal250
Trailering
It took 4 guys (we are all short) to pick up the full size bed on our 66. Take off the tail gate first...it seems to weigh more than the bed does.
Old Mar 23, 2012 | 07:00 PM
fordpt's Avatar
fordpt
Exclamation
I took off the rear bumper and brackets, and the rear tires, 33-12.50-16.5, put them on the ground behind bed, slid the bed back, and stood it up, and then upside down, to sandblast, by myself I was 24 then, now 52.
Old Mar 23, 2012 | 07:53 PM
tomrooster-1's Avatar
tomrooster-1
I removed my 8'bed similar to fordpt , I took off the rear wheels and lowered it almost to the ground then I jacked up the front end as high as I could with a floor jack then slied the bed back till I could get a floor jack under it then kept pushing it back till I could block it up with jack stands. I'm 65 and that was 2 years ago. Tom
Old Mar 23, 2012 | 11:19 PM
SuperSabre's Avatar
SuperSabre
I know most people won't have one of these, but if you do . . . I used a tractor with a front bucket and an engine hoist equalizer bar. I hooked the four chains on the equalizer bar through the four middle carriage bolts, with the equalizer giving me fore and aft balance, had a chain attached to the bar and the bucket, and let the tractor do the work. Don't forget there are six carriage bolts plus two conventional bolts at the back for a total of eight.
Old Mar 24, 2012 | 08:57 AM
schoo's Avatar
schoo
yea got the two bolts at back to remove today, don't know if i can grind or sawzall.but the nut on one side is on so hard that i need brakerbar and no room to get atit
i guess you guy's have a good idea how old people are by their spelling or something i'm close to those above.
Old Mar 24, 2012 | 11:48 AM
37 Ford guy's Avatar
37 Ford guy
I used the "4 guys method" to get my old bed off but they weren't around when I put the new one on.
The "cherry picker" method worked quite well for short bed..... I had the bed standing on end on a couple of flat dollies so I could roll it around. I positioned it behind the truck and tilted it over onto a 5 gallon bucket so I could roll the cherry picker under it. I cut a 4x4 to fit under the bed rails and attached a short chain. Voila! All by myself....
Old Mar 24, 2012 | 12:59 PM
schoo's Avatar
schoo
yea! and that looks like a custom cab also!
Old Mar 24, 2012 | 04:09 PM
OldHarley's Avatar
OldHarley
Those Custom Cabs are a killer, especially when you add the extra 14 oz. of weight for those aluminum bedside mouldings....Hahaha!!
OK, I guess you really meant the flareside beds are lighter since they can be done less the rear fenders...altho, I'm not sure how much lighter they really are.
Old Mar 25, 2012 | 10:27 AM
camperspecial65's Avatar
camperspecial65
a couple of suggestions...as to bed removal...ESPECIALLY on those self locking nuts...use a nut splitter...a very sound investment...another thing...if they are OE bolts...and those werent it sounds like...have a helper hold the head flat against the bed floor while you reef on them...and a wire brushing and a shot of PB Blaster works well too...
I swapped beds out on mine years ago...over a Labor Day weekend as I recall...I did it myself...TONS of lumber laying around, a few well placed jacks lots of patience and viola...
- cs65
Old Mar 25, 2012 | 10:32 AM
schoo's Avatar
schoo
yea pb blaster wd4000 got it off 4 guys thank god it didn't snow untill today
