Vibration in the frame
Old Mar 23, 2012 | 07:39 AM
SPCMarty's Avatar
SPCMarty
My 92' F150 4x4 developed quite the vibration. I can feel it while accelerating but goes away letting off the gas around 25-40mph but after 55+ is very noticeable regardless of accelerating or not, in neutral even.
Old Mar 23, 2012 | 08:06 AM
BigBlueOx's Avatar
BigBlueOx
You may want to crawl under your truck and check your U-joints. That would be the first thing that I would look at.
Old Mar 23, 2012 | 11:17 AM
bigpapa1987's Avatar
bigpapa1987
i would be looking at u joints and trans mounts and motor mounts .
Old Mar 23, 2012 | 12:54 PM
SPCMarty's Avatar
SPCMarty
I do have a fairly badly squeaking u joiny
Old Mar 23, 2012 | 01:18 PM
SPCMarty's Avatar
SPCMarty
Between 40-50mph I have a dead zone with minimal vibration
Old Mar 23, 2012 | 01:21 PM
Phy's Avatar
Phy
Replace the bad u-joint & then try it...
Old Mar 23, 2012 | 02:52 PM
SPCMarty's Avatar
SPCMarty
Any preferred methods to do so? I don't want to take the whole drive shaft out
Old Mar 23, 2012 | 05:41 PM
White 97 xlt's Avatar
White 97 xlt
If you don't want to take the driveshaft out, the only other option is let someone else do it.. Or wait until it comes apart on it's own..
The driveshaft will HAVE to come out................ Oh you could lay under it and fumble around with a press and get the joints in "maybe" but the best way is going to be remove the shaft and get it out where you can work on it....
Old Mar 23, 2012 | 10:52 PM
Encho's Avatar
Encho
The Southernmost Mod
In neutral you won't feel vibration from any u-joint, vibration in neutral idling only points at two possible causes: Engine or Transmision (this includes the Torque Converter) problems. The first one to check should be the Engine mounts, they have steel and rubber, see if the rubber is broken (take a good look, sometimes it's hard to spot any cracks), then check if the Engine needs a tune up, if it isn't working right it could vibrate. Then check the Transmision mounts (idk if they have several, i recall just one and usually only the Broncos have them), then check the Torque Converter.
In any case, there could be several factors at work causes some degree of vibration, worn u-joints, worn or deformed tires, broken bearings, frame cracks or broken weldings, radius arm bracket failures, Broken differentials (either the bearings or broken teeth in any of the gears)... Those are all i can recall right now, but i'm sure there are some more. As you can see, all the ones in this paragraph are of dinamic nature, which means you'll only perceive them while driving.
Old Mar 23, 2012 | 11:10 PM
RJJP's Avatar
RJJP
If he means stopped in neutral then I agree, but if he clicks it into neutral at speed and coasts then a U-Joint can still cause vibration.
Old Mar 24, 2012 | 12:17 AM
Encho's Avatar
Encho
I don't think he will coast in neutral, then again i'm assuming he owns an auto transmision, where I don't see any reason to put the truck in "N" while driving around.
Old Mar 24, 2012 | 12:27 AM
SPCMarty's Avatar
SPCMarty
The engine is running a-ok and the tires are about 7,000 miles old.
My u joint was squeaking already, and I had gotten stuck in mud, I'm sure the u joint didn't like the stress of rocking the truck in 4x4 to get out.
cb_13
2004 - 2008 F150
Aug 7, 2015 03:10 PM
bwep
2004 - 2008 F150
Jun 17, 2005 04:13 PM
Kenji
18
Feb 8, 2005 06:50 PM
East Side
1983 - 2012 Ranger & B-Series
Aug 1, 2004 04:24 PM
wolf81
Nov 9, 2003 08:54 PM
