Primer Question
Old Mar 22, 2012 | 11:02 PM
preppypyro's Avatar
preppypyro
Primer Question
Hey guys and gals,
Im working on a motorcyle tank, and I just have a primer question.
I have the tank stripped to bare metal, and I had to do a little filling and to do that I used some filler with fiberglass in it. (think its called everglass, fiberglass reinforced body filler)
I have some por 15 self etching primer that I have from when I painted my engine, and i was just wondering if this primer is acceptable to use over the bare metal, and the filler that has fiberglass in it.
If its not, what should I be looking for?
Any help is appreciated as I really would like to put a decent at home job on this motorcycle tank!
Old Mar 23, 2012 | 05:32 PM
Action4478's Avatar
Action4478
I Wouldn't use the Por.. You should use a direct to metal primer surfacer to even things out. Then finish it with 400 (or so ) grit wet ...
You may be able to get one in a rattle can . It will need to have some filling capabilities
Old Mar 23, 2012 | 09:24 PM
MP&C's Avatar
MP&C
I personally use House of Kolor epoxy primer, KP2-CF part a and part b. Sticks to bare steel, aluminum, fiberglass, and other materials as well.
71mach351
Aug 21, 2011 07:08 PM
Duke78
Paint & Bodywork
Sep 7, 2008 10:35 PM
Duke78
Paint & Bodywork
Mar 10, 2008 08:13 PM
Aekisu
Paint & Bodywork
Mar 30, 2006 11:58 PM
turbosek2
Paint & Bodywork
Feb 23, 2003 07:42 AM
