A few Ford F250/F-350 parts
Category: Interior
Price: $0
Private or Vendor Listing: Private Listing
Most of them were taken from a 96 F350 that was wrecked and the outside was damaged.
I've got a complete passenger door, glass linkages, etc. It is parts only since it was one of the damage areas on the outside. Make offers if you need anything from it.
I've got a hydroboost MC from a 97 F450. No cruise provision. Probably have a couple hydroboost lines I didn't use so I will ship those with it.
Working brake master and booster from a 96 f350.
I've got 3 serp belts from a 97 f350, 8 rib pully. I don't think they were ever used, but they don't have any packaging.
Various tan trim interior pieces from a 96 f350 crew. I've got the windshield trim.
Lower dash panel/by steering column.
Windshield to headliner trim.
Both b pillars with belts.
2 mint tan sunvisors.
I've got an ac compressor from this same truck. Unsure on condition.
I also have the factory underhood harness from this truck, e4od truck. It was cut by the PO when he was removing the engine. It will need to be soldered back together.
Factory spyder from the 96 f350.
Underhood insulation for a 7.3 diesel. This one will be expensive to ship so I may have to fold it in half to get a decent shipping rate.
I've got a 2012 f550 rear seat. It is a vinyl bench. It was pulled from a truck with 30 miles on the odometer in favor of black leather. It will need to have dust cleaned off it. But otherwise has never been sat in.
Not really sure what things are worth price wise so I will take offers on it. I mostly just need this stuff gone for the space.
The one where the fuse panel is and the little cubby on the right side of the steering wheel. Don't have the instrument cluster bezel unfortunately.
is the 96 f350 4x4 auto drw w/od ?
do you have the linkage rod for the transfer case ?
you can reach at brianbondo@yahoo.com or call 6172795737
thanks
brian
thanks
brian
Ghosteh
01-14-2016 09:28 PM
tubolove
Ford Truck Parts for Sale
13
05-19-2010 02:21 PM
